Cams, heads and emissions testing.
Is there a cut-off for cams where they will no longer pass emissions?
We have dyno testing here in MA, if that helps. I am planning on going with LTs with cats. Will retain stock EGR and AIR. Stock heads for this year, but with a cam. Been looking at the 220/220 - 222/222, 112 and 114 lsa ranges. Lift - .550-.570.
Does it HAVE to be a 114lsa to pass? Or will any cams in that range (pretty much T1/B1 and hammer cams seem to be the ones I've been looking at). I'd rather NOT go with the 114lsa because the car is a daily driver (14k a year) and moving the power band up a lot does not sound appealing to me.
So, is there any magic 'line' that you cannot pass? Is it JUST the lsa, or just the i/e durations? Lift? And finally, will ported heads change my emissions at all (by themselves)? Have any of you passed emissions with cams in this range? I don't want to be borderline either. Like I said, it's a daily driver. However, it does see the strip once a week or so.
Oh, and on a kinda off-topic question, those with T1/B1 and hammer (C1?) cams, what are your shift points? Just wondering the power ranges.
Dope
With stock heads, you could shift as high as 6400 rpm with this B1 and still be at or very near peak power from all the dyno graphs I’ve seen. Much above 6400 and the stock heads won’t breath too well, but with ported heads you could probably shift at 6600 with this cam, maybe even more. I had MTI set my shift points up, but I think they’re a little low (about 6200) and I might have them raised a little more to about 6300/6400. Remember though, the higher you spin the motor, the more stress you’re putting on the valve train AND bottom end.
Hope this helps...
Bottom line is I would suggest a 220/220 114 .56X Comp. You'll be fairly emissions safe and you're not leaving that much on the table compared to a 222/222 112 cam. you can make up any loss of low end power with slightly more stall or by getting some 3.73s.
Has anyone passed with the hammer cam?
Are there any tricks to use for the emissions testing? I've heard of hot-wiring the AIR pump, but I think that would only help at idle - at 3000rpm or whatever they make you do on the dyno, I think the cats would overheat.
Good info guys, appreciate the help.
Dope
Cheers,
Chris
<strong>I've got the hammer cam with stage two MTI heads with FLP's & cats, passed emissions with flying colors. also don't have EGR or air pump assembly. The trick with an A4 car is to test with the car in drive for the low load portion of the test. The car was inthe 600 to 650 range in park, but stick it in drive & it went down to 11!!!!!! Allowable limit here is 220. In the high load portion of the test(between 2300-2800 rpm) the car put out 1 hydrocarbon. Hope this helps. <img src="gr_stretch.gif" border="0"> </strong><hr></blockquote>
Are u saying that Houston Allows you guys 220 hydrocarbons?
The exhaust side of the set up consisted of MAC headers with the 3" collector mod, customer 3" y-pipe with CarSound 3" in/out high flow cats. I had just installed new O2s, as the shop that did my 3" y-pipe must have damaged the O2s when they did the work. The car was running rich on return to me.
Todd
