Bump Stop Mod ?
Dan
<strong>Mine doesn't look like it opens all the way, but I don't want to go messing around because I don't have an A-tap <img src="gr_sad.gif" border="0"> </strong><hr></blockquote>
you can use a voltmeter- thats how i did mine.
Dan
[ January 12, 2002: Message edited by: DanZ28 ]</p>
<strong>Did anyone notice a gain off of this??
I know it can't harm, I just don't want to mess things up...</strong><hr></blockquote>
Gained ~1.5 mph at the track by adjusting from 4.1 volts to 4.6 volts.
TRACTION CONTROL GUYS: About 95% of all ASR/TCS cars CANNOT achieve true WOT because of slack on the throttle cable. You can adjust this on traction control cars only. There is a knuckle adjusting thingy (don't know the technical name) in the middle of the cable. There is a snap ring holding the cable down on the knuckle, just pop that up by releasing the little tabs on each side, and pull the cable easily in either direction to loosen or tighten the cable. Keep checking your TPS voltage until you get the TB bump stop to touch completely. If this puts you past ~4.6 volts, just adjust until you achieve that.
Sorry for the sketchy directions. It's a VERY simple procedure, but at the same time kinda hard to explain without showing someone in person. Feel free to email me if you have any questions.
Josh
Josh
[ January 13, 2002: Message edited by: Damian ]</p>
<strong>
Josh
Josh
[ January 13, 2002: Message edited by: Damian ]</strong><hr></blockquote>
Dan,
I had to do this to mine when I put the BBK on.. I even had to cut the ends a little with a dremel to get it at WOT.. I'll show you this week if you have time..
When you told me you were doing this, I was thinking when you floor it, the rotating assemble on the throttle body was hitting the bump and you had to shave the bump back slightly to get 100% throttle..
Lets hook up this week and see if we can figure it out...
By the way, the code in my car went away as soon as I pulled out of the track. I think it was trying to scare me out of racing.. So I don't need your A-tap just yet.. Thanks man for letting me use it..
[ January 13, 2002: Message edited by: LIL SS ]</p>
I've got 4.3 volts with the it to the floor, but it's also reading it at 100% TPP--again, position of opening expressed as a percentage
Thx
[quote] By the way, the code in my car went away as soon as I pulled out of the track. I think it was trying to scare me out of racing.. <hr></blockquote>
LMAO, lol
