Trouble codes...HELP
Old Jan 11, 2002 | 09:47 PM
Stu's Avatar
Stu
Default Trouble codes...HELP
I am getting a P1416. I have no idea why. My mods are 4"Mufflex, 3.73 gears, TCI converter, EGR, Ported MAF, IAT sensor relocation and silencer ears removed, and TBBypass. My baby feels like it loads up with fuel when get the code. If I blip the throttle it clears for a moment. Please help, it doesnt happen all the time. It also seems like it only happens when the weather is warm...for Delaware... <img src="images/icons/confused.gif" border="0"> <img src="graemlins/camaro.gif" border="0" alt="[Chevrolet]" /> <-My girl <img src="graemlins/gr_devil.gif" border="0" alt="[devil]" />
Old Jan 12, 2002 | 11:32 AM
LS1derfull's Avatar
Default Re: Trouble codes...HELP
P1416 is right bank air injection problem,check hose and connections to check valve from air shut off valve(diaphragm on drivers side) if not the problem maybe check valve is faulty. PCM looks at o2 sensors to see if air pump is working ok so you may have a bad passenger side o2.
Old Jan 12, 2002 | 01:03 PM
Stu's Avatar
Stu
Hey LS1derfull. I havent touched my air pump so I hope nothing is wrong there, but I do have 4" mufflex so I think my rear O2 on the passenger side might be reading wrong. I'll check everything to see whats wrong. Also my air pump hollers at me sometimes if its cold in the morning,you think maybe it could be going TU?
Thanx
[ January 12, 2002: Message edited by: LS1Lover ]</p>
Old Jan 12, 2002 | 01:17 PM
LS1derfull's Avatar
LS1lover, if your airpump itself was going you would have p1415 dtc also, thats why i said to check only passenger side of air system. Mufflex shouldnt have affected rear o2 unless install damaged sensor, check o2 sensor with scan tool to see if its lazy or broken. Checkvalve should only work in one direction
Old Jan 12, 2002 | 07:17 PM
Stu's Avatar
Stu
Thanx for your help. I checked everything physically and it looks good. I'll see if I can find someone in De. with ATAP.
Old Jan 12, 2002 | 08:45 PM
98blackSS's Avatar
hehe.. I feel like a broken record for all these P1416 responses. <img src="gr_tounge.gif" border="0"> More than likely you have a bad passenger side check valve. Very common problem. P1415 for bank 1 valve. These are pretty cheap and I've had one go bad myself. I would say if it were anything else, you would have other codes as well. Wanna be 100% sure? Swap valves from side to side and keep watch of the codes. I think they are like $12-15 at napa.
Old Jan 12, 2002 | 10:14 PM
Stu's Avatar
Stu
Thanx 98blackss. I will giv it a shot. Im really impressed with the help I am getting thru LS1Tech. Keep up the good work fellas. <img src="gr_grin.gif" border="0">
