Stock Head Flow #'s
Old Jan 13, 2002 | 01:42 PM
Marty's Avatar
Default Stock Head Flow #'s
Anybody flowed any stock heads? If so what did they flow(and at what lift)?
Old Jan 13, 2002 | 03:55 PM
LS1derfull's Avatar
Default Re: Stock Head Flow #'s
LS1 stock castings @28"
Int. Exh.
.200"=137cfm .200"=104cfm
.300"=136
.300"=187cfm .350"=150
.350"=207 .400"=165
.400"=223 .450"=172
.450"=228 .500"=179
.500"=237 .550"=183
.550"=242 <img src="graemlins/burnout.gif" border="0" alt="[Burnout]" />
Old Jan 13, 2002 | 03:57 PM
LS1derfull's Avatar
Had a little trouble with page setup, first .300"
reading is exhaust flow
Old Jan 13, 2002 | 03:58 PM
BIGBOS's Avatar
What are the stock valve sizes?
Old Jan 13, 2002 | 04:00 PM
Marty's Avatar
[quote]Originally posted by BIGBOS:
<strong>What are the stock valve sizes?</strong><hr></blockquote>
2.00/1.52
Old Jan 13, 2002 | 04:01 PM
Marty's Avatar
anybody flowed them to .600
[ January 13, 2002: Message edited by: Marty ]</p>
Old Jan 13, 2002 | 04:46 PM
LS1derfull's Avatar
Marty i have the .600" #s somewhere but i cant find them, If you look at the flow curve youll see gains tapered off at .550, starting to choke so i would guess to say 246cfm and 186cfm.
Old Jan 13, 2002 | 05:02 PM
Marty's Avatar
[quote]Originally posted by LS1derfull:
<strong>Marty i have the .600" #s somewhere but i cant find them, If you look at the flow curve youll see gains tapered off at .550, starting to choke so i would guess to say 246cfm and 186cfm.</strong><hr></blockquote>
Thanks Bud,
Hey is you do find the exact #'s please post 'em
Old Jan 13, 2002 | 05:04 PM
Jason99T/A's Avatar
I can shift faster than you.
[quote]Originally posted by Marty:
<strong>
2.00/1.52</strong><hr></blockquote>
Actually, they are 2.00/1.55
Old Jan 13, 2002 | 05:07 PM
Marty's Avatar
[quote]Originally posted by Jason99T/A:
<strong>
Actually, they are 2.00/1.55</strong><hr></blockquote>
my bad, it was a guess
Old Jan 13, 2002 | 05:08 PM
BIGBOS's Avatar
Some stage 2 heads offer 2.02/1.57 valves it doesn't seem like that big of a difference... <img src="images/icons/confused.gif" border="0">
Old Jan 13, 2002 | 05:55 PM
LS1derfull's Avatar
Bigbos, SAM(Judson) has gotten 290cfm intake and 210+ exhaust with 2.02 and 1.6 valves, so valve size isnt as important as port work to making good #'s. Big valves need bigger than 3.900" bore block also, thats a big commitment.IMO
Old Jan 13, 2002 | 05:57 PM
y2khawk's Avatar
<img src="gr_grin.gif" border="0"> ARE's number from GMHTP
http://harlan.sketchy.net/head_flow.html
<img src="graemlins/formula.gif" border="0" alt="[Pontiac]" />
Old Jan 13, 2002 | 06:09 PM
Marty's Avatar
Thanks a bunch Guys,
Couple more questions.
1) Anybody know what the stock 5.3's flow?
2) I know the 6.0 heads are said to be similar to the ls6 heads, do they flow the same? If not then what do they flow?
3) How much would you have to mill the 6.0 head to achieve 11/1 comp. w/ stock pistons?
4) What all do you have to change after milling heads(pushrods?)?
Marty
