Can TR-6, gapped at .043 affect NA performance?
Old Jan 14, 2002 | 01:06 PM
JC's Avatar
JC
Default Can TR-6, gapped at .043 affect NA performance?
huh?
I ran a 8.0@90 w/ 2.0 60'
On a 1.91 60' I ran 7.8@92
I added a shortbelt,front runners,ported stock TB,took out seats,disconnected swaybar and still ran a 8.0@90 w/2.0 60' And the air was freezing. What tha dealy yo? Is the plugs?
Old Jan 14, 2002 | 03:55 PM
Colonel's Avatar
Default Re: Can TR-6, gapped at .043 affect NA performance?
It's most certainly not the plugs. Look elsewhere. Any Autotap data?
Old Jan 14, 2002 | 03:59 PM
Slow Z28's Avatar
do you have an auto or a manual? if it's a manual, possibly slower shifting on that last run would cause that slow down. if it's an auto, autotap data will be needed for us to help out more like colonel said.
Chris
Old Jan 14, 2002 | 11:15 PM
guadofreak's Avatar
I run TR6's all the time NA. No loss in power at all. The colder plug seems to help w/ pingng also! <img src="graemlins/fluffy.gif" border="0" alt="[Fluffy]" />
Old Jan 15, 2002 | 07:53 AM
JC's Avatar
JC
[quote]Originally posted by Colonel:
<strong>It's most certainly not the plugs. Look elsewhere. Any Autotap data?</strong><hr></blockquote>
Well I do know that for some reason I was real timid with my shifting this time.
Also the Atap data looks normal. If anything the o2 are around .91x-.92x @ WOT, and that's on 2% lean.
Old Jan 15, 2002 | 10:54 AM
Slow Z28's Avatar
well there you go, the shifting will alter your times and mph.
were these on different days? even though the air is colder, it could still affect you in a bad way.
chris
Old Jan 15, 2002 | 01:40 PM
TXCAMSS's Avatar
"All Motor 9 Second club member"
Yep,Air density / humidity will make all the difference in the world.Make sure your Throttle arm is touching the bump stop on your TB.The cable may slipped during the mods.Been there done that.It's good for a full 3/10ths loss. I know this from experience, but it is a quick fix and you get your piece of mind back. Good luck.
Old Jan 16, 2002 | 09:43 AM
Colonel's Avatar
I'd be curious to know what your timing advance was at WOT too.
