Timing Advance on my 2002 sucks! Help!!!!
Old Jan 15, 2002 | 09:43 AM
Joel_SS's Avatar
Default Timing Advance on my 2002 sucks! Help!!!!
All,
Autotap'd my 2002 last night. With a lid and stock maf I was getting about 19 degree's on average @ WOT, and no Knock retard. O2's were .940 to .960
I put a ported MAF on the car and got about 21 degrees on average @ WOT. But I averaged about 1.9 deegree's KR with the ported MAF, and the car was running very lean! O2's were .820 to .840
What cam I do to get my timing into the 25+ range at WOT without KR and running too lean?
Old Jan 15, 2002 | 10:05 AM
02 'Hawk's Avatar
Default Re: Timing Advance on my 2002 sucks! Help!!!!
01-02 don't see as much timing because of the new cam. 24/25 is good. Dunno why you are so rich then that lean. Reset the PCM. See what it does.
I run 88.x/89 at WOT with OEM MAF, Lid, 0 KR
Old Jan 15, 2002 | 10:20 AM
Joel_SS's Avatar
Will do thanks..
Do you think taking the MAF screen out of the stock maf would help??
Old Jan 15, 2002 | 10:25 AM
RPM WS6's Avatar
LS1Tech Administrator
Community Influencer
I have a friend with an ’02 WS6. He was seeing 25 degrees advance with 0 KR at WOT after removing the MAF screen and doing a home port and polish job on the MAF. His O2s were in the .910 range after the MAF work.
My ’00 WS6 got 27.5 degrees of advance with a totally stock MAF at WOT before custom tuning.
Old Jan 15, 2002 | 10:28 AM
rom3's Avatar
With Direct-flo lid and stock everything else I'm getting a max of 25 degrees timing with 0 KR around 5,700 rpm's with my '01. O2's are richer than my '99 was. The B1S1 is averaging around .905 until 5,000+ RPM's where it drops down to .895 or so. This is with 93 octane gasoline.
What octane gas are you using? 19 degrees sounds low even on an '01/'02. At what RPM's are you taking this measurement?
Old Jan 15, 2002 | 10:41 AM
Joel_SS's Avatar
[quote]Originally posted by rom3:
<strong>
What octane gas are you using? 19 degrees sounds low even on an '01/'02. At what RPM's are you taking this measurement?</strong><hr></blockquote>
I am using 93 octane. 19 degree's is my average throughout the enite rpm range..
Old Jan 15, 2002 | 10:44 AM
RPM WS6's Avatar
[quote]Originally posted by Joel '02 Hawk:
<strong>
I am using 93 octane. 19 degree's is my average throughout the enite rpm range..</strong><hr></blockquote>
What are you getting in the 5000 and up range? What about just before the upshift?
Old Jan 16, 2002 | 07:12 AM
02 'Hawk's Avatar
<strong>Will do thanks..
Do you think taking the MAF screen out of the stock maf would help??</strong><hr></blockquote>
Don't **** with the MAF. Wrong time to do experiments. No real reason to change it for what you have anyway. Figure out timeing issue first. don't forget warranty/dealer too.
