Largest cam with a stock stall converter...?
Old Dec 12, 2006 | 01:25 PM
B4CU's Avatar
Default Largest cam with a stock stall converter...?
I know a stall is the way to go, but I do not want one yet. Before you say "Hey, get a stall." read the rest of this post. I am looking into putting a cam into my 2001 A4 and I was wondering what is the biggest you can go on a stock stall converter? I want a cam with more torque down low than anything (2,000-5,000 rpm range). What would you suggest? Let me know of any setups that you have seen that are similar to what I am asking. Also, I will be getting it tuned if that makes a difference in how large you can go.
Old Dec 12, 2006 | 01:33 PM
ArrestMeRed99Z28's Avatar
this is the second thread of it's kind today, try a search.
AJ
Old Dec 12, 2006 | 01:49 PM
lt1formula2000's Avatar
instead of just saying try a search everytime, if we know where the other thread is maybe we should just help each out sometimes so here's a link man
https://ls1tech.com/forums/showthread.php?t=623140
Old Dec 12, 2006 | 02:29 PM
jimmypop13's Avatar
look at the GM hot cam or something in the higher 21x/21x range, probably on a 114-116 lsa. i would think this would work with the stock converter though i'm not positive
Old Dec 12, 2006 | 02:32 PM
SLPSS99's Avatar
I would get a 3500 stall first then start looking into cams, just my opinion. But if you are looking into to cams look at a ZO6 cam or the Hot cam with stock converter
Dan
Old Dec 12, 2006 | 02:49 PM
Jordan S.'s Avatar
I ran a .595/.595 232/232 on 112+4 with stock stall when my verter was getting rebuild. Drove just fine, didnt die once.
Ran like a dog but drove just fine.
Old Dec 12, 2006 | 03:27 PM
YankeeVert.'s Avatar
The GT2-3 cam will give you 25/30 HP over stock and Idle better than stock.It's a little bigger than the LS6 cam and is a great baby cam. You can also use the Z06 springs.
GT2-3: 207/220,.571/.578, 118.5 LSA
Old Dec 12, 2006 | 03:33 PM
Slowhawk's Avatar
LS1Tech Sponsor
Like you'll read many times, Changing the converter will make your car faster than a Cam swap on a stock converter.Also a converter should be changed before a Cam swap.
Old Dec 12, 2006 | 06:43 PM
B4CU's Avatar
AJ
"I want a cam with more torque down low than anything (2,000-5,000 rpm range). What would you suggest?" Please read the whole thing. I wanted to know what other people had/ liked. Either make a suggestion or don't post at all, d-bag. Thanks. Moving on...I don't want to put a different stall in my car right now, that is the whole point. I know that a stall will drop 1/4 times like nothing, but I don't have the money for that right now. I will probably look into the hotcam or something like that. For those that actually helped, thank you.
Old Dec 12, 2006 | 08:01 PM
cws T/A's Avatar
http://video.ls1tech.com/recentvideo...68017a291a.htm
Old Dec 12, 2006 | 08:45 PM
Ragtop 99's Avatar
For your rpm range you need a tight LSA cam with an early IVC. How big, that's a matter of what idle speed and idle quality you are willing to accept. something like a 214/220 113 110 would get some grunt at 2000 rpm but run out of breath in the higher rpms. You'll make it idle easily at 750. A little bigger: 218/220 112 110.
Both can use an XFI intake lobe and Xer exhaust lobe. You still should do a converter instead of this, but these will do what you are asking for.
Old Dec 12, 2006 | 08:50 PM
Snyper's Avatar
I was going to say the same thing.
Old Dec 12, 2006 | 09:10 PM
hammertime's Avatar
Since money is an issue, have you priced all the parts for a proper cam swap? Thunder Racing's packages start at 599.99 for their 220/220 114 cam with single springs. Thats about the best you do to make power from 2000 - 5000. Add an oil pump, gaskets and timing set (all recommended) and you're talking another $200 - $250 or so. If you're paying for the labor, factor that in too.
On the other hand, converters start at about $500 plus much less labor to install. Then you are ready later when you decide to get a cam.
Just something to think about
Old Dec 13, 2006 | 12:33 PM
B4CU's Avatar
I already have a ported LS6 double roller from a swap that I was going to do and then decided against. I am going to get used springs pretty cheap and a cam is easier than a stall. I would want a good converter which would cost more than $500. Throw in the diff. cover, deep pan, cooler, and shift kit and you got yourself quite an expensive/ time consuming project. Also, I don't want my tranny to blow up any time soon.
Old Dec 13, 2006 | 12:38 PM
B4CU's Avatar
Your link is for this thread. I don't know if that was supposed to be funny or something or if you did it on accident.
Old Dec 13, 2006 | 12:42 PM
slick1851's Avatar
Get A Stall!
Old Dec 13, 2006 | 12:43 PM
hammertime's Avatar
Looks like you have researched this pretty well...
Good luck to you with the build!
Hammer
Old Dec 13, 2006 | 12:56 PM
B4CU's Avatar
Originally Posted by slick1851
Get A Stall!
Brilliant! Why didn't I think of that? So are you going to mail me a new tranny in about five months?
Old Dec 13, 2006 | 12:58 PM
B4CU's Avatar
Hammer
Yeah, I don't just post without knowing a little something first. I really do wish I could do a stall. Thanks for the suggestions.
Old Dec 13, 2006 | 02:56 PM
LeftySS's Avatar
i have a 99 ss a4 with stock stall and a gm hot cam and after tuning and setting idle to 750 it does great. Bottom end is great but also have 3.73s so that makes some difference. Run the car with 315s on the rear and they won't hold the road in first gear and spin pretty good shifting into second. But if you get this cam make sure you get a good tune other wise it is a headache to drive, bad idle and dying. that 750 idle is without drilling a hole in throttle body as well. but if i had it to do over again don't think i would mess with a cam with this much overlap. would probably do a Z06 cam instead. My $.02
