Largest cam with a stock stall converter...?
Grow up? Who was the one that put this?
"Don't worry...the STV (stall-to-valve) clearance has yet to be an issue with any aftermarket cam grind. Just to be safe though, get some clay and check it. You only need to turn the motor over twice by hand. As long as there's no valve imprints in the clay on the stall, you should be good."
All I was saying is that you should try to not be an enormous douche sometime. As for my last post, at least it was funny. I see you can't take a joke. I guess you lose your sense of humor when you "grow up."
