Heads and Cam Questions!!
Old Dec 13, 2006 | 01:11 AM
TopRPM's Avatar
Default Heads and Cam Questions!!
Ok guys!!
I finally decided on a cam and heads package.. I purchased it today.. Should be here by monday!!
Ok... A couple of questions!!
1st- The heads are milled .010.. What type of head gasket should I go with??
2nd- Anything I should look at getting while Im in there.. Motor has around 106k on it....
Thanks in advance guys!
Old Dec 13, 2006 | 05:24 AM
seawolf18's Avatar
What heads did you get and what size c. chambers do they have?
Old Dec 13, 2006 | 07:20 PM
JPH's Avatar
JPH
Originally Posted by TopRPM
Ok guys!!
gm mls head gaskets, oil pump, timing set, pushrods for sure. lifters, well depends on condition and camshaft size?
Old Dec 13, 2006 | 10:33 PM
TopRPM's Avatar
Im getting Lifters... I already have the Pushrods.... Im getting an LS6 ported Oil pump....
Wheres the best place GM MLS head Gaskets
TopRPM's Avatar
The cam is the TR224
Old Dec 13, 2006 | 10:46 PM
N4cer's Avatar
I always order mine from Summit because they're close. But just find one of the sponsors and call them. Ask if they're actually IN STOCK and READY TO SHIP. You gotta ask some of these places, and even then they might not ship when they claim they will.
Old Dec 13, 2006 | 10:50 PM
TopRPM's Avatar
Ha.. yeah well lets not knock the sponsors.. There the reason were able to be on here..
Does anyone have a part number?? The heads are milled .010
Old Dec 13, 2006 | 10:55 PM
N4cer's Avatar
That's why I mentioned no names.
If you call even a local GM dealer one of them will have them. Just ask for the GM head gaskets for a 2002 Camaro V8. Then when you pick them up, make sure they're MLS (multi-layered steel).
Old Dec 13, 2006 | 11:10 PM
TopRPM's Avatar
Gotcha!! Thanks for the help buddy!
