Valve Stem Damage - Anyone seen this before?
Old Dec 17, 2006 | 12:27 PM
vettenuts's Avatar
Default Valve Stem Damage - Anyone seen this before?
I have been rebuilding my stock heads now that the Darts are on the car. I have them disassembled and today was getting ready to clean the valves when I found this on every valve, but the worst are the exhaust valves. Anyone seen this happen before? Looks like the valve lock bit right into the valve stem material.
Old Dec 17, 2006 | 12:33 PM
Irocss85's Avatar
is that a stock valve then? Ive never seen that before. wonder what would happen if you had 10deg. keepers, and 7deg. retainers? could that be a possiblilty? or the reverse?
Old Dec 17, 2006 | 12:38 PM
vettenuts's Avatar
No, these were machined 7* locks made by the same company that made the retainers.
Old Dec 17, 2006 | 12:50 PM
chriswtx's Avatar
stock exhaust valves have a hardened tip welded on top of them. The line between the hardened tip and valve stem is normal.. I have a brand new set of stock valves and they all look like this..
Old Dec 17, 2006 | 12:54 PM
chriswtx's Avatar
Quick edit...All the exhaust valves are like this..This a pic of an exhaust valve??
Old Dec 17, 2006 | 01:38 PM
vettenuts's Avatar
Yes, I don't see this on the intake valves at all. There is like a groove that goes all the way around the valve, which just happens to line up with the top of the lock.
Old Dec 17, 2006 | 01:39 PM
chriswtx's Avatar
Yep, normal...Its all good..
Old Dec 17, 2006 | 03:02 PM
vettenuts's Avatar
Thanks for the info, I thought it was odd that only the exhaust since a float issue would tend to affect the heavier intake valve first. And all the exhausts are the same and all the intakes don't have this.
Wonder if anyone ever had this joint let go?
