Futral f13 114 vs 112 LSA
Internet Mechanic
Speaking purely about cams i that on a N/A motor the same cam grind #'s with a difference in the LSA.
With a 112 LSA you will make better low end torque vs. the 114, the 114 will not make any more peak hp then the 114. Hence the 112 is better. This stating that all things being equal the 114 will make 1st gear suck compared to the 112 and once each hits the power band the race will be done with the 112 LSA car beating the 114.
Although if mated with some FI the 114 will make over all better power. (not saying this cam is a FI spec grind, its just that comparing the 2, the 114 would fair better).
As for emissions a set of brand new cats and lean tune will pass yea easily.
Location: Your girl's back door giving her the long stroke while you're at work
Originally Posted by SOMe WS6
i love my fm13 114 lsa. absolutely no problems with the cam.
