Which Oil pump and timing set?
Old Dec 22, 2006 | 09:39 PM
jtl12419's Avatar
What's the part no. for the LS4 oil pump and the LS2 timing chain? How do you know it flows more- is it higher pressure or higher volume?
Will the oil pump fit on the LS1/LS2 block without modification?
Originally Posted by 1LoudTA
LS4 OIL PUMP (yes ls4 the new 5.3L LSX motor in the fwd impala ss) dont go any other way, more pressure and volume than an ls6 pump, have one in my car and its great.. get it from www.fredbeansgmparts.com
and its cheaper also only 62 bucks
Old Dec 22, 2006 | 09:50 PM
jtl12419's Avatar
Where was a LS4 pump tested to flow more than a stock LS1/LS6 pump?
Old Dec 22, 2006 | 10:33 PM
Cobra4B's Avatar
Don't have the PNs on me... it's a higher volume pump... it's needed to drive the displacement on demand of the new 5.3. My buddy Joe C (HPADDICT) just put one in when doing his LPE blower cam in prep for his blower on his '99 FRC.
The car has more pressure everywhere... this will be esp. good for me w/ my oil cooler and running higher oil temps at HPDEs. The higher volume pump will keep pressure up even as the oil heats up and thins out.
Old Dec 23, 2006 | 08:06 AM
1baddls1's Avatar
+ another
LS4 pump & LS2 chain
Old Dec 23, 2006 | 11:27 AM
Katech_Jason's Avatar
LS1TECH Sponsor
Originally Posted by dlc1609
katech offers a replacement chain also. you use your factory sprockets. they say it's used on the c5r race car and to their knowledge, none of these chains have ever failed. i'm thinking they are $100 or a little more though.
Thats correct. $139.94 and never failed in all C5-R racing and durability testing.
Old Dec 23, 2006 | 12:03 PM
SmaknaSS's Avatar
Is that the JWIS chain?
Old Dec 23, 2006 | 07:40 PM
LS1TECH Sponsor
yea
_
Old Dec 23, 2006 | 08:44 PM
Josh's Avatar
Can anyone confirm that the LS4 pump will fit an LS1 without requiring any modifications?
Josh
Old Dec 24, 2006 | 01:14 PM
Gannet's Avatar
I know everyone wants a "bigger" (higher pressure and/or volume) oil pump, but is there any evidence that is necessary? Are LSx engines prone to bearing or other failures due to inadequate oil supply?
What do the endurance road race guys run?
