On the LS1 engine.....
Old Jan 27, 2002 | 04:07 PM
MrTransAm's Avatar
Default On the LS1 engine.....
on the driver side cylinder head at the front of the head, is that brass bolt sticking out with the sensor in it the water temp fitting?? If so, I've found where to install my Autometer mechanical water temp gauge.
Old Jan 27, 2002 | 04:12 PM
Jake99SS's Avatar
Default Re: On the LS1 engine.....
Yep, water temp. found that out when I accidentally left the sensor unplugged after changing plugs.
Old Jan 27, 2002 | 04:14 PM
gwj's Avatar
gwj
From: Live Oak, FL - in the woods where the creatures lurk.
Yes. You'll have to have a fitting to keep the stock sensor also, though. And I've heard you cannot tap into the existing sensor wire to run a separate gauge. There are other places on the block to put a fitting, if you'll do a search you'll find a thread.
Old Jan 27, 2002 | 04:27 PM
MrTransAm's Avatar
Well this was my thought. Find a Y fitting that will screw into the head and on one point of the Y screw back in the stock sensor and on the other point screw on the Autometer sensor. Will this work or will I have an inaccurate reading??
Old Jan 27, 2002 | 04:33 PM
227Hawk's Avatar
With the gauges we have? accuracy?,Now
that's FUNNY <img src="gr_eek2.gif" border="0"> Aftermarket should
be fine like that
<img src="graemlins/gr_cheers.gif" border="0" alt="[cheers]" />
[ January 27, 2002: Message edited by: las vegas hawk ]</p>
Old Jan 27, 2002 | 04:42 PM
Ryan 98SSA4's Avatar
in the passenger side head there is an open port for the temp gauge.
Ryan
Old Jan 27, 2002 | 05:09 PM
MrTransAm's Avatar
Thanks for the replies guys, i appreciate them. Is the port youre talking about on the passenger side head where the port is on the drivers side head??
Old Jan 27, 2002 | 05:20 PM
98blackSS's Avatar
[quote]Originally posted by MrTransAm:
<strong>Thanks for the replies guys, i appreciate them. Is the port youre talking about on the passenger side head where the port is on the drivers side head??</strong><hr></blockquote>
Yep.
Old Jan 27, 2002 | 05:50 PM
MrTransAm's Avatar
[quote]Originally posted by Ryan 98SSA4:
<strong>in the passenger side head there is an open port for the temp gauge.
Ryan</strong><hr></blockquote>
i dont see where you're talking about. Can you be more specific??
Old Jan 27, 2002 | 11:27 PM
between the last two exahust ports it looks like an Allen head bolt going into the side of the head.
Ryan
Old Jan 28, 2002 | 01:30 PM
blazer96's Avatar
ryan is correct. any like some of the people said, you cant tap into the stock sensor. wont work.
bob <img src="graemlins/gr_chug.gif" border="0" alt="[chug]" />
