SC 382 Parts pic
Here is a pic of all the parts i have gotten so far(Lunati 4340 crank, LS6 intake, Comp Cams cam/springs/timing set, J&E rings, Crane Cams 1.8 rocker kit, Manley valves, King engine bearings, ARE oil pump, Autometer boost/fuel/air fuel guages and guage pod). Thats about $6K laying on my floor. Still waiting on pistons and rods. More pics to follow as this project progresses.
![](http://64.176.33.161/albums/Amanda-and-Chris-98-Ram-and-others/abr.sized.jpg)
[ January 29, 2002: Message edited by: Jackyl_30 ]</p>
Jackl_30,
Does the SC mean supercharged? I'm about to get a 382 all-bore project started (tomorrow). What kind of RWHP/RWTQ numbers are you expecting? What kind of idle do you expect?
Thanks
Thanks
[quote]Originally posted by Quickin:
<strong>Jackl_30,
Thanks</strong><hr></blockquote>
Yes, it does mean supercharged. I am going with a Vortech T trim. It's a custom job. I plan on running 12 or 13 psi. I am hoping I can crack the 600 rwhp barrier. I have even heard some folks say that this could make 700 rwhp. Don't know about that for sure. Not sure what kind of torque this will make. Does anyone have any idea?
<strong>Jackl_30,
I've built a'many 'closet' motors. (buy parts untill you run out of things to buy. then it's ON TIME!) LET US KNOW.
<img src="graemlins/gr_hail.gif" border="0" alt="[hail]" />
LS1Tech Premium Sponsor
[quote]Originally posted by Jackyl_30:
<strong>well the Vortech will come with bigger injectors. Also I will be getting an in line fuel pump.</strong><hr></blockquote>
With that kind of power, I'd look at more than an inline fuel pump! You need to get a better intank pump as well IMO. You're going to be feeding a LOT of fuel!
I just talked to RMCR. The place that's doing my work and they said 38lbs injectors will be ok, but we are going to upgrade my in tank pump and also have an inline pump as well.
[quote]Originally posted by Ls1 346ci SS:
<strong>sweet dude. Make sure you hang that crank if you can and not let it sit to long on the side or it can warp.</strong><hr></blockquote>
this is true for long periods of time and especially if they lay on concrete
LS1Tech Co-Founder
I had to get an intank pump for ARE just to keep up with my 422ci motor.
I have a buddy with a 96Z 355ci LT1 and they plan for 15lbs of boost... Bigger intank for sure. Tom is going to run 50 or 55's.
