can rod bearing be replaced without .....?
Old Dec 21, 2006 | 04:00 PM
chevroletman's Avatar
Default can rod bearing be replaced without .....?
is it posible to replace rod bearing without removing the heads or crank on a 2002 6.0 iron block truck motor? the motor ran upside down for a while and must mave spun a bearing .
Old Dec 21, 2006 | 04:55 PM
Cop Car's Avatar
yes, but it would take lots of tricks and cost you more money than to remove the crank. so remove the crank and have it polished
Old Dec 22, 2006 | 11:42 PM
DJMRTS's Avatar
I had all my rod bearings and rod bolts replaced while the motor was still in the car (vette). Had to remove the front spring to get the oil pan off. Its a task to plasti-gage the bearing clearances though.
Old Dec 23, 2006 | 12:03 AM
Dustin 98TA's Avatar
If it spun a bearing, most likely the crank is scored. I would recommend pulling it and turning it.
Old Dec 23, 2006 | 04:48 PM
Meegle's Avatar
Agree. The spun bearing more than likely chewed up the journals to the point where a simple polish won't clean it up.
Also the big end on the rod probably needs to be inspected as well so unfortunately the short block has to come apart.
If this is a quick/budget fix than you can get away with it but don't sell it to anyone you know
Old Dec 23, 2006 | 06:15 PM
BlackScreaminMachine's Avatar
Internet Mechanic
Spun is spun. Only time I have seen it not mess up the crank is if the crank wa a forged piece, thats bout it.
Old Dec 23, 2006 | 06:39 PM
bigdsz's Avatar
About 45 years ago I spun a bearing on a 1955 Ford I had. A guy from the machine shop came out and had some kind of machine that resized the journal with the engine in the car. I kind of doubt if that's still done these days.
Old Dec 24, 2006 | 12:49 PM
eallanboggs's Avatar
If he resized a crank journal by just pulling the pan while leaving the engine in the car and not removing the crank back in the late 50s he must have had his MoJo workin!
