Would I be dumb buying heads/cam w/o knowing if I will go FI, Bore/Stroke, or N20????
![](https://ls1tech.com/forums/images/ranks/ls1tech20year.png)
I can get a great deal on stage 3 heads/cam and wanna get a set really bad, and my future plans include either
1. Bored/stroked engine with spray
2. Bore/stroke & forced induction,
3. Just heads cam and spray
I haven't decided yet which combo I wanna go with, but I was wondering if it would be much wiser to wait until I know exactly which combo I'm gonna use???
Is there a head/cam combo that will work with all these combos????? Believe it or not I'd still like to pass emissions in the future too...
[quote]Originally posted by verbs:
<strong>I can get a great deal on stage 3 heads/cam and wanna get a set really bad, and my future plans include either
Is there a head/cam combo that will work with all these combos????? Believe it or not I'd still like to pass emissions in the future too...</strong><hr></blockquote>Any of these combos would be nice.you should email some of the sponsors about your set ups and see what they say.As far as I know you can use the stage 3 setup on all of the above.Its your preference on wether you want to go forced induction or juice.Just make sure if you do one or the other you have a stot bottom end and fuel to match.Better to run fat than to run lean.
A stage 3 combo would be a good choice for you, but just incase you don't want to spend much money I have a nice stage 1 heads/cam setup for sale for $1000. <img src="gr_images/icons/wink.gif" border="0">
I have a set of ARE S1's for sale too, not as cheap as Terry's S1's though <img src="gr_images/icons/wink.gif" border="0">
Problem with doing the heads/cam before the new motor is that the bottom end size influences your cam selection and head selection. If you buy a set of heads ported for the stock 3.9 bore when you go all bore (4.1 bore) you will need to have your chambers opened up and likely a larger valve. (2.08/1.60) plus all the porting changes accompanying it.
Good luck,
Chris
Good luck,
Chris
[quote]Originally posted by Chris ARE 360:
<strong>
Good luck,
Chris</strong><hr></blockquote>That's what I was afraid of....I know that if I go the stroker/bore route many times heads/cam comes with it as a package.
Would a stage 3 head setup and B1/T1 cam be OK to use for forced induction or spray at a later date???
<strong>
Good luck,
