LGM cam install... do I need to degree the cam? Does anybody?
Originally Posted by PREDATOR-Z
That is why, Confucius says
" only a fool orders a cam with any advance ground in
![The Jester](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_jest.gif)
![Winky](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_wink.gif)
Originally Posted by hammertime
To tight of an intake clearance can sometimes be resolved by retarding the cam a couple degrees.
Originally Posted by connecticut
you really got the cam from Comp w/ the LG specs
54-000-11 lobe/lobe lsa
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
![The Judge](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_judge.gif)
the cam is probable ground right.the problem lies with all the componets that connect the cam to the crank. if the cam gear is of by 1/2 degree,the crank gear off or the crank keyway of by 1 or 2 degrees then when you add it all together it could be off. degreeing the cam lets you know if its installed acording to the cam doctor graph you got,iff not thats the only way you will know.
LGM themselves install their cams dot-to-dot. They only degree at customer request.
(metionned by LGM on this board in another discussion)
To add to your security in the dot-to-dot:
We used a degree wheel and dial indicator to measure the specs on my cam, and the LSA and ICL were exactly where they were supposed to be.
I have a theory because so many cams differ even though they're the same grind. Like 2 cams of the same name can measure somewhat different. I think that when the company sends an order to Comp, they have a certain margin of error that they accept. And I think that each company sets their own margin of error. Apparently LG has very stringent standards on what they'll accept.
Originally Posted by N4cer
LOL
I see you're joking. But I gotta ask: why not order a cam with advance when 95% or more of us have stock, non-adjustable timing sets?
This is either done on a dyno or by trial an error at the track.
So for the poeple who can, straight up no advance is the chosen method.
That is when the QTP 2 piece front cover comes in handy.
Look at it this way, the advance/retard is a tuning tool for cam power and in turn is a VE modificator.
From my one experience I'd say degree it. Installed what was supposed to be a torquey cam and went from 350rwtq to 352rwtq. Bought an adjustable timing chain and had it degreed and then went to 382rwtq.
LOL retard would be the right word for it. You'd then not have the desired valve events that you wanted when buying the cam. Then the car doesn't run like it should. That's just a horrible fix that loses performance instead of increasing it.
I realize retarding the cam moved the VE's, but had only suggested it as a measure to increase PTV clearance. Ideally, you would pull the heads and cut the pistons for clearance, but some people don't want to do that.
