Need some figures, people!
Joseph's comments in an old thread: [quote]First you want to divide the stroke in half, so that you can measure from the centerline of the crankshaft bore.
3.9" stroke /2 = 1.95"
Use the actual rod length 6.125"
Now add these 2 numbers together = 8.075"
Take the results of adding these together and now you subtract the block deck height 9.24" - 8.075" = 1.165"
1.165" of compression height on a piston would give you close to zero deck, meaning the piston would be flat with the cylinder head surface at top dead center, assuming a true block.
Stock LS1 engines have the piston out of the cylinder .006-.007" out of each cylinder, so to duplicate that with compression height just add the .006" to the 1.165" that we came up with earlier.<hr></blockquote>
Ok, to check my math, I'd like to get some stock LS1 numbers since I think Lunati may push the piston out .015 from the deck height. I know the stroke is 3.622 and the rod is 6.098. Whats the compression height? ANY info would help....and I'd LOVE some sponsor support here. Im probably doing ALL this wrong. <img src="images/icons/rolleyes.gif" border="0">
Ryan
[ February 02, 2002: Message edited by: The Underdog ]</p>
Stock LS1
Stroke: 3.62
Rod: 6.098
Compression Height: 1.338
That makes a stack 9.246" tall, deck height is 9.24 which throws the pistons up .006"
J.
Ryan
