looking for some advice... H/C swap
I will be installing Heads Camshaft and a Stall Converter
I'm trying to put together my shopping list for EVERYTHING I will be needing for the swap (every gasket, nut, bolt, etc.)
This is what I have come up with thus far...
I know I have to be missing alot
please feel free to add and make suggestions
some have been purchased some have yet to be ordered
CNC LS6 Heads (61cc) (recent special from Patriot) w. free OEM headbolts
MTI Stealth II camshaft (224/220 .581/.581 116+0 LSA)
Comp Cams stock length Chrome Moly pushrods
LS7 Lifters
LS4 oil pump
LS2 timing chain
LS6 intake manifold
Yank 3600 stall converter
ASP 25% underdrive pully
ARP Rod bolts
Pacesetter ceramic coated Long Tube Headers
Pacesetter Off Road Y-pipe
SLP PowerFlo cat-back exhaust
!AIR
!EGR
LS6 Head Gaskets MLS off 02 Z06's measure .54 compressed i think
Intake Manifold Gasket Set
Exhaust Manifold Gaskets
Valve Cover Gaskets
Vapor Vent Pipe Seals
Water Pump Gaskets
Front Cover Seal
Front Cover Gasket
Harmonic Balancer Bolt
Oil Pan Gasket
im also debating pulling the motor to do everything & make sure everything is good
as oppose to fighting in the engine bay & underneith doing the rod bolts 1 at a time from under the car
help me complete my list please
any comments concerns advice is greatly welcomed
-and of course a tune
-depending on what ls6 intake you have you might have to get a freeze plug.
-get several zip ties to tie up the o2 sensor wires.
mike
-locktite for cam bolts
-don't know how many miles you have on your car, but might as well do water pump and tstat while you have everthing off!
fredbeansgmparts
is where im getting it from
ill post a GM part # for it in a bit too
Plus its really designed to work w. manifolds cats etc etc
ill see better results with the combo
i know of 420rwhp w. this combo thru an A4
heads 995
cam 419
ls6 intake 300
chrome moly pushrods 130
LS7 lifters 100
lifter trays ??
LS4 oil pump 70?
LS2 timing chain 40?
seals gask?
fluids?
pully/bolt.belts 220
torque converter got a SICK DEAL... 200
Headers/ORY w. cut out/slp dual dual 250
TOTAL thus far is aprox $ 3,000
