switching from Hotcam to T1
Old Feb 5, 2002 | 01:03 PM
CHRISPY's Avatar
Default Re: switching from Hotcam to T1
I would look at the TR224 cam on 112LSA <img src="gr_stretch.gif" border="0">
Good luck,
Chris
Old Feb 5, 2002 | 01:07 PM
JC's Avatar
JC
[quote]Originally posted by Chris ARE 360:
<strong>I would look at the TR224 cam on 112LSA <img src="gr_stretch.gif" border="0">
Good luck,
Chris</strong><hr></blockquote>
I would but, I can get the T1/springs/retainers for $400. <img src="gr_grin.gif" border="0">
The Hotcam gives me 115trap speeds. Would I see any improvement with the T1?
Old Feb 5, 2002 | 02:02 PM
Trevor @ Texas Speed & Perf.'s Avatar
LS1Tech Premium Sponsor
Active Streak: 30 Days
Active Streak: 60 Days
From the local cars I've seen dyno on the same dyno w/ all of the bolt-ons, the T1 consistently puts down 8-10 RWHP more with better streetability. The hotcam has a choppier idle and less streetability IMO. A single-pattern cam will be more streetable. If you can do the swap yourself, I'd definitely do it. You'll be able to get some money out of the hotcam setup, and I think you'll be happier w/ the T1. It's worth a try IMO for $400!
__________________
Old Feb 5, 2002 | 02:37 PM
Visceral's Avatar
If you have stock heads, you likely wont pick up anything. THe GM Hotcam was designed for the flow rations of the stock GM LS1 head. I took advantage of that and made 396hp on stock heads with a Hotcam. If you have aftermarket heads, the cam choice will depend on what the flow of the intake and exhaust ports are. Often times ppl have found good luch with single patterns since most porters go for the 75% E/I flow ratio, which historically is where a single pattern cam made sense. The T1 works rather well over a huge range of cars. You cant lose really if its an M6.
Chris
Old Feb 5, 2002 | 02:42 PM
JC's Avatar
JC
[quote]Originally posted by Visceral:
<strong>If you have stock heads, you likely wont pick up anything. THe GM Hotcam was designed for the flow rations of the stock GM LS1 head. I took advantage of that and made 396hp on stock heads with a Hotcam. If you have aftermarket heads, the cam choice will depend on what the flow of the intake and exhaust ports are. Often times ppl have found good luch with single patterns since most porters go for the 75% E/I flow ratio, which historically is where a single pattern cam made sense. The T1 works rather well over a huge range of cars. You cant lose really if its an M6.
Yeah but, you added a pulley and the LS6 intake. I make 371/378 on stock LS1 intake. I wonder if the T1 will give me 10 more?
Old Feb 5, 2002 | 03:53 PM
Visceral's Avatar
I dont think it will. I also had a MAF translator, which picked me up about 10-15 rw.
In my sig below, you can see what got me where:
\chris
Old Feb 5, 2002 | 04:25 PM
Lane's Avatar
You're doing everything you can to not buy that rear-end aren't you? <img src="graemlins/gr_angel.gif" border="0" alt="[angel]" />
Old Feb 5, 2002 | 09:43 PM
gator's 99TA's Avatar
the numbers puzzle me, as some guys are getting 370+ RWTQ. i only got 357 RWTQ but 365 RWHP. is there something wrong in my motor? i dont understand. the TQ is really nice and flat.
Old Feb 5, 2002 | 09:46 PM
BIGBOS's Avatar
With my cam that is similar to the C1 "hammer" cam
the specs are
222/222 .563/.563 112lsa
I made 360rwhp and 350rwtq....very smooth chart and I only took it up to 6300 rpms...it would of probably peaked at like 6600 close to 370rwhp....
I still have stock programming......except for the HPP3 "programming" <img src="images/icons/rolleyes.gif" border="0">
I plan on stepping up to a more aggressive cam soon....I'm interested in that new G5 cam.... <img src="gr_grin.gif" border="0">
Old Feb 5, 2002 | 10:31 PM
LEO's Avatar
LEO
T1 cam! <img src="graemlins/gr_judge.gif" border="0" alt="[judgement]" />
Old Feb 6, 2002 | 12:58 AM
JC's Avatar
JC
Default switching from Hotcam to T1
Will I pick up anything? Is it worth it? Say if I can get the T1,springs, retainers for $400
Old Feb 6, 2002 | 10:02 AM
thxone's Avatar
Where are you getting a T-1, springs, rods and retainers for only $400.00. Let others in on the secret.
Old Feb 6, 2002 | 10:05 AM
JC's Avatar
JC
thxone,
I'm buying the cam used.
Lane,
$2250 is ALOT OF FREAKING MONEY!!! <img src="gr_eek2.gif" border="0"> I'll buy a rearend when I HAVE to. <img src="gr_stretch.gif" border="0">
Old Feb 6, 2002 | 10:10 AM
i only paid 2150 for my Moser 12bolt, ABS, 33 spline, 4.10, HD posi, etc!
also could someone explain the lack of TQ on my motor?
Old Feb 6, 2002 | 10:16 AM
MechMan's Avatar
JC
I allready did the same thing you are doing.
I had the hot cam 1st then swapped it out for a T1. This is what the # were for both.
Hotcam 389 rwhp and 375 tq
T1 393 rwhp and 390 tq But I also added
LS6 intake between the 2 dyno's
Hot cam at the track my best was a 12.49@114 1.90 60' on a cool night.
Now T1 and intake Ive gone 12.05 @117.98 1.94 60'
in the Fl summer heat.
The T1 didnt dyno much higher but at the track
and on the street there's a world of difference.
Old Feb 6, 2002 | 05:23 PM
Go Texas Tech's Avatar
JC,
I don't think it's worth the trouble unless you like doing cam swaps for fun or can get free labor. I would save up for the 12-bolt + 4.11's.
Old Feb 7, 2002 | 01:22 AM
Snake Skinner's Avatar
I have the hotcam along with other mods...look in my sig for more details. Anyway I am really pleased. I put out 406/431 with my mods listed in my sig. I have stock valves in my heads still, I don't think I'll pick up much with bigger valves or a different cam. That's my opinion though. I thought about doing a switch to the TR 224 cam and also to the Hammer Cam, if it's successful I might try it, keep me posted.
Brian <img src="graemlins/camaro.gif" border="0" alt="[Chevrolet]" />
Old Feb 7, 2002 | 07:19 AM
mgreen's Avatar
[quote]Originally posted by MechMan:
<strong>JC
and on the street there's a world of difference.</strong><hr></blockquote>
How can you even compare the Hotcam to the T1 when you added the LS6 intake at the same time?
(I'd ask a similar question in regards to the intakes if you said that you gained ~3mph from swapping from LS1 intake to LS6 intake (but you swapped cams between your passes/dynow) )
Old Feb 7, 2002 | 08:17 AM
JC's Avatar
JC
I decided not to get the T1. A LS6 intake would accomplish as much as a cam upgrade.
The Hotcam seems to be doing the job for me. (115 trap speeds.) I'm just going to save the money for a strong rearend.
Old Feb 7, 2002 | 09:24 AM
Damian's Avatar
LSX Mechanic
I have never been impressed with the results that the Hotcam produced. I usually see M6's trapping 114-115 with this cam. That doesn't really show me much considering my car trapped 115 with stock internals, stock clutch, stock gearing, and full weight.
The T1 would is definately the way to go, even with stock heads. The single pattern will idle MUCH better, and perform better with aftermarket heads. Just a cam swap may only show 10 rwhp peak, but net 20 rwhp midrange gains.
T1 all the way. The Hotcam is 350 bucks for a shitty idle IMO.
Josh
