Hooker LT problems, HELP!
If you have SFCs, don't even worry about it. I think it's meant to hold the floorpan sides in place. Not a biggie if you have other bracing.
BMR I believe sells a version of the brace that has plenty of space as well. It's called a Tunnel Brace I believe.
Regardless of the fact that you can very easily fit a 3" pipe under there (I personally do), taking it off won't kill ya.
Dope
-Allen
If removing that mid brace bothers you alot, just go down to your local hardware store and buy 4 1/2 longer bolts and 4 nylon or aluminum 1/2 washers to "shim" it away from the pipe. But if your decide to "pitch it" like Ron said, theres no real harm done especially if you plan on installing SFC's. Good luck! and have fun.
