Strange stuff after header install...
Old Feb 7, 2002 | 10:20 AM
BADWS6's Avatar
Default Strange stuff after header install...
I had the macs with high flows installed on my car. Now my car is hesitating like crazy when I nail it and backfiring like crazy. Anyone know what may have caused this to happen. It seems like I have no power now. WTF? ANyone?
Steve
01 WS6
Old Feb 7, 2002 | 10:44 AM
jpolser's Avatar
Default Re: Strange stuff after header install...
it sounds like you have a leak somewhere. Mine used to do that until I fixed an annoying leak.
Old Feb 7, 2002 | 10:46 AM
BADWS6's Avatar
thanks...I know we have to replace a band clamp on my Borla. I didn't know it could screw with the car that bad. <img src="images/icons/confused.gif" border="0">
Steve
Old Feb 7, 2002 | 10:51 AM
2000 Camaro SS's Avatar
yup a leak will allow the O2's to read the wrong sending the wrong signal and in turn adjust the air/fuel wrong. Also look to make sure the spark plug wires are on tight to the plug. One other possibility is this... After I had my SLP LT headers installed one of my O2's went bad I could tell by AutoTap I bought a new one and it was fixed.
Old Feb 7, 2002 | 10:52 AM
RPM WS6's Avatar
LS1Tech Administrator
Community Influencer
Maybe a spark plug wire came loose or got burnt?
Old Feb 7, 2002 | 11:00 AM
BADWS6's Avatar
Now that I think about it...that almost 100% is the case. I was getting nervous thinking something was really wrong. I have a real bad leak in my exhaust that I was gonna replace it today and hopefully cure the problem.
Steve
Old Feb 7, 2002 | 01:01 PM
Mark IXZD 150's Avatar
Make sure none of your wiring harnesses are laying on or are too near the headers. You may have cooked some wiring. That's pretty common too.
Old Feb 7, 2002 | 02:07 PM
BADWS6's Avatar
I've got it over there right now getting looked at. I hope its nothing serious.
Steve
01 Ws6
Old Feb 7, 2002 | 02:19 PM
BADWS6's Avatar
It was a cracked plug. Everything is fine now.
Steve
Old Feb 7, 2002 | 02:33 PM
CRAGER's Avatar
Administrator
[quote]Originally posted by BADWS6:
<strong>I smoke crack with a buttplug. Everything is fine now.
Steve</strong><hr></blockquote>
....ok? lol <img src="gr_grin.gif" border="0"> j/k <img src="gr_grin.gif" border="0">
How did you find out it was a spark plug? Did you pull it out, or did you take your car back there?
I'm glad everything is cool now, but your still slow! <img src="gr_images/icons/wink.gif" border="0"> j/k
Peace,
Craig.
Old Feb 7, 2002 | 02:43 PM
BADWS6's Avatar
LOL!!! you pole smoker...I took it back over there and they replaced all of them with Tr55s. Oh btw, your gonna see the tailights again! <img src="gr_grin.gif" border="0">
[ February 07, 2002: Message edited by: BADWS6 ]</p>
Old Feb 7, 2002 | 08:42 PM
CRAGER's Avatar
Administrator
<strong>LOL!!! you pole smoker...I took it back over there and they replaced all of them with Tr55s. Oh btw, your gonna see the tailights again! <img src="gr_grin.gif" border="0">
[ February 07, 2002: Message edited by: BADWS6 ]</strong><hr></blockquote>
...just not yours!!!
Old Feb 7, 2002 | 09:00 PM
zombiedude's Avatar
By the way. O2s Read Exshaust in Relation to OUT SIDE OF THE O2. It compares. Exshaust Leak? Off readings. Oil burn smoke?( oil on manifolds/pipe) OFF READINGS. Remember how it works. Hopes this helps. <img src="gr_stretch.gif" border="0">
Old Feb 7, 2002 | 09:29 PM
Glad to hear it was nothing expensive to fix. <img src="gr_images/icons/cool.gif" border="0">
Old Feb 8, 2002 | 01:53 AM
CRAGER's Avatar
Administrator
[quote]Originally posted by 2000 Camaro SS:
<strong>Glad to hear it was nothing expensive to fix. <img src="gr_images/icons/cool.gif" border="0"> </strong><hr></blockquote>
Ditto! That is cool that it was something cheap and simple.
BADWS6(Steve)- Here's the $100 dollar question:
So you changed the plugs out, how about the wires? Take a look to see if they keep those little heat sheilds around the stock wires (if you kept your stock wires). So you don't end up melting them down the road.
Peace,
Craig.
Old Feb 8, 2002 | 09:06 AM
BADWS6's Avatar
Crager-haven't checked the heat shields yet...I'll let you know. You'll find out what the result will be when I get the cam installed in the next couple weeks... <img src="gr_grin.gif" border="0">
Steve
[ February 08, 2002: Message edited by: BADWS6 ]</p>
