TR6 Plugs: Any Advantage for High Compression Motors?
My ARE S2 heads should be milled to 10.8:1 or even slightly higher compression. Is there any advantage to running a colder plug like the TR6 (instead of TR55) in terms of being able to either run a little more timing or a slightly leaner mixture?
Re: TR6 Plugs: Any Advantage for High Compression Motors?
I think a colder plug is a must with the much more turbulent air charge coming into the cylinders and the higher compression. These two factors can lead to detonation very quickly so yes, a TR-6 and the right gap would be ideal <img src="gr_grin.gif" border="0">
So long as you're not getting detonation I see no reason to run a cooler plug.
12.2:1 compression and TR-55 plugs here.
If I were trying to run pump gas on the street I would be running TR-6s.
