98-02 stock cam specs
Old Feb 11, 2002 | 03:40 AM
johnl_96Z/02TA's Avatar
Default 98-02 stock cam specs
Anyone have them, or know of a web page that might list them?
lift, duration, lsa
Old Feb 12, 2002 | 04:01 AM
Default Re: 98-02 stock cam specs
ne1?
[ttt]
Old Feb 12, 2002 | 06:05 AM
Tin Indian's Avatar
From what I have read:
98-00 LS1 202/210 .472/.479 117.0 LSA
Base circle 19.7 mm (0.776”)
01-02 LS1 198/208 .500/.500 115.5 LSA
Base circle 19.7 mm (0.776")
Old Feb 12, 2002 | 06:46 PM
thanks.....
I haddn't found the 98-00 info yet
Old Feb 12, 2002 | 06:52 PM
LS1derfull's Avatar
01-02 lift is incorrect specs are: intake=.464" and exhaust is.478"
Old Feb 12, 2002 | 06:59 PM
XLR8NSS's Avatar
Adkoonerstrator
I thought the '00's had .500/.500 for the lift. <img src="images/icons/confused.gif" border="0">
I guess my '01 cam is just a teeny tiny blower cam. <img src="gr_grin.gif" border="0">
Old Feb 12, 2002 | 11:27 PM
FireSquawk's Avatar
LS1derfull, sorry sir but YOU are incorrect. The lift for the F-body cam is .500/.500. The Y-body cam is a .472/.479 spilt for a supposedly smoother idle and for the dual exhaust. <img src="gr_images/icons/cool.gif" border="0">
Old Feb 13, 2002 | 03:30 AM
XLR8NSS's Avatar
Adkoonerstrator
In '01 the F-body cam was changed and I am pretty sure it is smaller than .500/.500 lift so you can't just say the f-body has one cam for all the years. <img src="graemlins/gr_judge.gif" border="0" alt="[judgement]" /> <img src="gr_images/icons/wink.gif" border="0">
Old Feb 13, 2002 | 04:59 AM
Directly from my 02 FSM [sec.5.7L Unit Repair pg 6-497]
cam lobe lift-Intake: .324
cam lobe lift-Exhaust: .322
What's the math to get to the typically published spec? The manual dosen't specify if that's at .006 or .050 or anything, just states the actual lobe lift at the cam. I thought that number is multiplied by rocker ratio, which put's it at .550 & .547
NE1?
Old Feb 13, 2002 | 06:12 AM
jswhite's Avatar
johnl- Those last lifts are for the 02 LS6 can I think.
Old Feb 13, 2002 | 01:08 PM
LS1LT1's Avatar
In the event that it makes any difference....keep in mind that the '98-'00 F-body LS1s had EGR while the '01-'02s, as well as all C5 LS1s, did not. There were/are provisions on the cam for each respective application. <img src="gr_stretch.gif" border="0"> <img src="graemlins/burnout.gif" border="0" alt="[Burnout]" />
Old Feb 13, 2002 | 01:14 PM
Bad Habit Bird's Avatar
The o1's and 02's have a smaller cam than the previous year F-bodies due to not having an EGR setup.
Old Feb 13, 2002 | 06:14 PM
[quote]Originally posted by jswhite:
<strong>johnl- Those last lifts are for the 02 LS6 can I think.</strong><hr></blockquote>
Ahhh.... you are so right. My bad... guess I shouldn't be trying to flip through the service manual too quickly early in the morning.
Corrected data: [FSM pg 6-491]
lobe lift-intake: .274
lobe lift-exhaust:.281
With the correct factor for rocker ratio of 1.7, that's .466I, .478E.
Yup....I like the Z06 cam spec's better!
[ February 13, 2002: Message edited by: johnl_96Z/02TA ]</p>
Old Feb 13, 2002 | 07:09 PM
LS1derfull's Avatar
Firesquawk, my specs are correct, this info is right off GM SI2000 website, under 2001-2002 fbody engine specs, this is the same cam as 6.0 litre truck engine cam. This is fact and im sorry if you disagree.
Old Feb 13, 2002 | 09:07 PM
02 SOM WS6's Avatar
I copied this down not too long ago:
[quote]Stock cam specs
We put the cam that came out of Jason99TAs motors on the Cam Doctor last weekend and it was 200/210 499/499 117lsa.
Paul
www.thunderracing.com
1-877-516-7223
<hr></blockquote>
