battery dies after one week
Even if it's 2-3 days between startups, I get the RRR-RRR-RRR then it starts.
I did notice the wipers hadn't completely descended from when I shut the car off the week before last. The A/C switch was set to defrost too. Would either of these drain power even though the fan was off and the ignition was in the off position?
What's a good brand of battery to use instead of Delco? Was thinking either a regular Champion battery for ~$40 or a yellow top Optima.
I have no charging problems.
You need to check alternator, maybe change your battery cables.
JOHN
[ February 11, 2002: Message edited by: Matt 01SS ]</p>
<strong>Ryan, do you leave the alarm set all the time? I wouldn't think that'd make a difference but...</strong><hr></blockquote>
Yep. Alarm is set full time. Just to give you an example, it sat from the middle of Oct last year till mid-December when I took it out to test the PCM. And you remember the PCM issue I had (no need to get into that again), but point is I had to crank on it A LOT, and even after 2 months of sitting (with alarm on), and then cranking on it intermittently for over 10 minutes (hoping it would start) the battery never sounded weak.
I've bought used cars with Delco batteries that I know have had years of use on them, and I put even more years on with them still being good. Sounds to me like the quality control for these batteries is letting some (too many) bad ones slip by...
I had AC Delcos in other cars like RPM and they were great. One lasted 7 years and was still good when I sold the car
