Decided to change my cam with the new combo
The cam I was originally going with was a 226/234 557/575 lift on 112LSA.
The new cam will be 228/228 .588 lift 112LSA with the XE-R 3724 lobes.
Should peak around 6400-6500 and hold it to 6800 no problem. The lobes on this cam are VERY aggressive and the double springs are mandatory with this cam. Should be very interesting to see how it works out. Also Nick should have LS1edit in the shop by then and can tune the car in perfectly for the new combo. They are working on my heads now and are very happy with how things look so far.
Here is a summary of the combo (Only the heads and cam are new):
ARE 360 shortblock with forged rods and pistons, offset ground crank
5.3L trucks heads with 2.02 1.60 valves
11.2:1 compression
LS6 intake with Ported Throttle body
228/228 .588 lift 112LSA custom grind with the XE-R 3724 lobes
MAC headers with ported primaries and collector mod, Offroad Ypipe
3 intermediate pipe with cutout, and dynomax Ultraflo welded three inch muffler with 3 inch tailpipe and single 3.5 inch chromed tip.
12 bolt with spool 4.11's
4L70 tranny with manual valvebody and TP4400 converter
Centerline warrior 15x7 inch rims and Hoosier 26x9 inch slicks
right rear airbag
Warrior Skinnies up front.
Little bit of weight reduction (Approx 100 pounds)
Hoping for some good times this season... <img src="gr_grin.gif" border="0">
Cheers,
Chris
[ February 12, 2002: Message edited by: Chris ARE 360 ]</p>
Why the switch to a single pattern, did you give up the bottle in the last 12 hours? <img src="gr_images/icons/wink.gif" border="0">
I guess the limitation of the lobe profile is the lifter's ability to withstand high spring pressure?
Oh yeah, modify those MAC's even more, get rid of the ball joints on them and put some nice reducing elbows on them. See if PaiN has an old picture of his modified MACs, same thing Brooke did.
Tony
I am curious to see how the lifters will work, I am hoping the stock lifters will be ok? I am sure Nick knows what is best <img src="gr_stretch.gif" border="0">
I am going to shift the car around 6600 depending on the power peak with the cam and how the converter reacts.
Tony I will look into that for sure. Do you know where I can get pics?
Ragtop, I am not going to be running a huge shot of juice if I run any juice at all. I would require a converter change, and gearing/tire change to run the spray. Going to dial in NA first and then if things look good maybe a 150 shot next season with 28 inch slicks and a TPE 4100 converter.
Thanks,
Chris
If I can hook and hit a 1.4-1.5 sixty the times should be quite good I am hoping <img src="gr_grin.gif" border="0">
222 .581 is 3721
224 .581 is 3722
226 .585 is 3723
228 .588 is 3724
230 .592 is 3725
232 .595 is 3726
234 .598 is 3727
236 .602 is 3728
They go up to 248 .615 <img src="gr_eek2.gif" border="0">
Did Nick mention having to grind the rockers for clearance with the double springs? I remember someone on one of the LS1 boards mentioning it, but I never did it with my K-800's, and don't have any problem as far as I know <img src="gr_stretch.gif" border="0"> Thanks.
Hmmmm...... what about for cams between 236 and 248? Where can I see the list?
Gotta plan for a new cam myself with the new motor <img src="gr_grin.gif" border="0">
Tony
Nineball, I have the sheet from Comp I can fax to you.
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2022 Cadillac Escalade 6.2L A10 S&B CAI, Corsa catback.
2023 Corvette 3LT Z51 soon to be modified.
Custom LSX tuning in person or via email press here.
No biggie, Ive done it lots on several cars now. The corner of the rocker is curved, and you can just use a Dremmel to square it out.
Im curious about the following: Is the weight of the big 2.08 valves going to prohibit some of us who even have the dual valvesprings from running lobes like this?
Also... PLEASE watch out for the K800s. Your mileage may vary (YMMV), but they were deflating my stock lifters. I moved to the Cranes listed in the sig.
\chris
I would think my 228/228 112LSA .588 lift cam would be fairly similar in peaks to your 226/226 113LSA cam .585 lift.
Cheers,
Chris
