Coated pistons Vs uncoated pistons...... step inside
Ordering pistons tomorrow for my new motor and debating whether the coating is worth the additional cost. This motor will see 150 to 200 shot of nitrous occasionally at the track and be driven around on the streets as well. Seems Diamond wants almost 400 bucks extra for a fully coated piston. Is it worth it? Anyone tore down a motor with coated pistons to see if the coating was still intact or is this something that simply burns off after install? Please, no speculation, just facts. TIA guys.....
On a FI motor I would get the thermal barrier (crowns coated) for sure - nitrous it probably isn't as big of an issue - esp. for only a 150-200shot. If it isn't to much more you might look into that though (full coating probably includes the low-friction skirt coating also).
Chris
Chris
Polydyne coating does it for like $300 thats the sides and the tops. I say its worth it for peace of mind since you most likely spray it on the street also and temps can run higher on the street.
The ceramic coating on the tops is really worth it. It will keep the heat from passing through the piston. It also does not burn off after you run it. Now on the other hand, the moly skirt coatings due wear off after they have been run. When you pull the pistons out after running them you will notice that they have a wear pattern on the skirts. If you are going to due anything, get the tops coated.
Thanks,
Chris Gelineau
Diamond Pistons
877-552-2112 toll free
Thanks,
Chris Gelineau
Diamond Pistons
6600 rpm clutch dump of death Administrator
PolyDyn rocks.... I have all my GN stuff coated.
http://www.polydyn.com/
Information
Polymer Dynamics, Inc.
4116 Siegel St.
Houston, TX 77009
Phone (713) 694 - 3296 or
Toll Free 1-888-765-9396
Fax (713) 694 - 6915
Information
4116 Siegel St.
Houston, TX 77009
