Head Bolts
Old Jan 2, 2007 | 12:58 PM
FANCHERFAST's Avatar
Default Head Bolts
how many people have reused the head bolts on the LS1 heads?
Old Jan 2, 2007 | 01:20 PM
vettenuts's Avatar
I would wager to guess nobody, since the manual specifically states do not re-use.
Old Jan 2, 2007 | 01:24 PM
RiceKilla's Avatar
They are torque to yield, you can get a new set for 28 bucks from the dealer.
2000TransAmWS6's Avatar
no sir... it is not a good idea to reuse them
Old Jan 2, 2007 | 01:37 PM
Xtnct00WS6's Avatar
Do not reuse them. I'd even suggest to not even use the stock style bolts. Get the ARP's...you'll be thankful you did.
Old Jan 2, 2007 | 01:53 PM
Gauge's Avatar
11Second Club
Arp Ftw
Old Jan 2, 2007 | 04:53 PM
I wasn't going to. just wanted to know if anybody else had. can you fit the heads under the cowl with the ARP studs? let me know
Old Jan 2, 2007 | 05:30 PM
JPH's Avatar
JPH
heads must go on first, then install studs. i recommend arp myself.
Old Jan 2, 2007 | 07:47 PM
Mssingkid's Avatar
Unless your making BIG power, or some sort of power adder, i'd just get the ARP Head Bolts. A bit cheaper than the studs i might add...Not having to do the whole TTY makes them worth the cost alone.
