so exactly why are some switching to 5.3 L heads?
WTF?
Why are you some of you guys putting 5.3 truck heads on your cars? <img src="gr_images/icons/wink.gif" border="0">
Are you doing it for the increased compression? Is it really work the loss in flow (in stock form) over the 5.7 heads?
IF you want the compression why not do it RIGHT and change out the pistons? :squint:
LOL!
Less milling to get high compression but you have to do port work to get the flow numbers up there again. I am shooting for 11.2:1 comp out of my ARE 5.3L heads.
Cheers,
Chris
Cheers,
Chris
![](https://ls1tech.com/forums/images/ranks/ls1tech20year.png)
I dont know of anyone putting stock 5.3 heads on there car. People get the 5.3 heads ported to flow like ported 5.7 heads and then bolt on the 5.3's because of the smaller combustion chambers.
[quote]Originally posted by vmoore:
<strong>I cant believe you did not do a search.. <img src="gr_stretch.gif" border="0"> </strong><hr></blockquote>
:squint: I don't need to search I'm here all the time. <img src="gr_stretch.gif" border="0">
I just don't understand paying good money for truck heads and THEN spending even more to have them ported. :shrug:
If you are getting a Stage 2 head from a vendor the cost is the same. Core charge (AFAIK) is the same. They both require porting and valve change.
Cheers,
Chris
Cheers,
Chris
(as compared to buying a set of LS6 heads or spending more money on a set of LS1 5.7 heads.)
If you want the compression, change the pistons.
It just reaks of "cheap" to me.
[quote]Originally posted by Chris ARE 360:
<strong>If you are getting a Stage 2 head from a vendor the cost is the same. Core charge (AFAIK) is the same. They both require porting and valve change.
Cheers,
Chris</strong><hr></blockquote>
I did not realize the cost was the same, but then again I do my own head work.
I understand, now.
Cheers,
Matt
Cheers,
I understand, now.
Cheers,
Matt
That depends on cam choice, AF ratio and timing advance but if you use 93-94 octane and a reasonable timing curve you will be fine <img src="gr_grin.gif" border="0">
Chris
Chris
