What about a catch can for PCV ...
Old Feb 18, 2002 | 10:03 PM
Chris99WS6PWTMET's Avatar
Default What about a catch can for PCV ...
instead of connecting to intake manifold?
I just removed my LS1 intake to install an LS6 intake and I couldnt believe the amount of oil burned/coating the cyl. head intake runners. What a crying shame!!
So as we're looking at it, we're thinking (to the best of our ability) why not just get a catch can with a breather on it and run lines from the back of both valve covers to the can. Then block off the intake port, the TB fresh air line, and the passenger valve cover "fresh air" in line.
Is there any way this would work? Does the PCV have to vent into the intake?
[ February 18, 2002: Message edited by: Chris99WS6PWTMET ]</p>
Old Feb 19, 2002 | 08:19 AM
Default Re: What about a catch can for PCV ...
ttt
Old Feb 19, 2002 | 09:40 PM
Hmm... still no takers on this.
Well we've done some more playing around with it and actually made a 2 1/2 by 5 inch catch can with a cylinder in the middle welded to the top(like an inverted glass) to try out. The plan is to run from both valve covers into the side of the can, then out of the top of the can/inner cylinder to the stock PCV valve at the intake.
Our aim is to slow the air down enough for the oil mist to seperate from the air before being drawn through the inner cylinder and back to the intake.
Any thoughts on this idea??
I tried to "draw" a cutaway using text but it jumbled all to the left!! <img src="gr_sad.gif" border="0">
[ February 19, 2002: Message edited by: Chris99WS6PWTMET ]</p>
Old Feb 19, 2002 | 09:56 PM
steve's Avatar
ive been doing that for some time. occasional drain of the collected oil is all that needs to be done. works well.
steve frank
Old Feb 19, 2002 | 09:57 PM
99 WS6's Avatar
I just spent a few minutes trying to do the "text drawing" and when I deleted it, I noticed yours was gone. I have been thinking about using a catch can modified by adding a baffle or some coarse steel wool to separate the oil mist out. I figured it shouldn't be too hard. The only problem I could think of is condensation in the can, but that really would not be too bad because it would have to be drained periodically anyway to get the oil out.
Old Feb 19, 2002 | 10:19 PM
mmiller's Avatar
Texas Director
Someone needs to manufacture this type of set up and sell it on LS1Tech.com. They could make a few bucks and make it simple for those who need a PCV set up like this.
Old Feb 19, 2002 | 10:24 PM
steve, a few questions for you then.
1. Do you have a breather vent on yours?
2. Do you have anything in the can (mesh/filter/etc)?
3. Has it kept the oil from entering your intake?
Thanks in advance for any info you may be able to provide.
99 WS6,
I should have the car back together in a week or so. I can let you know how it goes. If it works we'll get some pics of it.
Old Feb 19, 2002 | 10:26 PM
thefritz1's Avatar
Look for the SMH mod at http://www.geocities.com/stevenmh_ws...ML/pcv_mod.htm
he sell complete kits that are kind of pricey but he is an awesome guy.
[quote]Originally posted by mmiller:
<strong>Someone needs to manufacture this type of set up and sell it on LS1Tech.com. They could make a few bucks and make it simple for those who need a PCV set up like this.</strong><hr></blockquote>
Old Feb 19, 2002 | 10:42 PM
zombiedude's Avatar
www.installuniversity.com shows a good PCV mod. Hope this helps. <img src="gr_grin.gif" border="0">
Old Feb 19, 2002 | 11:35 PM
thefritz & zombiedude,
Thanks for the replies. I have already checked all those sights out. What I'm trying to do is incorporate a catch can into the equation so a to not have those extra filters laying all over the intake like the Hovis mod. (No disrespect SMH!! Your fix is awesome, I'm just trying to go more cosmetic! Also, thanks for the quick email response yesterday!)
Old Feb 19, 2002 | 11:38 PM
Jamie99TA's Avatar
I would NOT disconnect the PCV from the intake. You really need the vaccum line hooked up so it can relieve the crank case pressure. Venting to a catch can is not enough to relieve the pressure and you will get some blow by which is not good. I have the line from the valve covers going into a catch can, then a hose to the pcv valve, then a hose to the intake. It works pretty good until 3-4 ounces of oil collects in the can. Here is a pic of what the can looks like. Its just a big fuel filter.
Old Feb 19, 2002 | 11:53 PM
Thanks Jamie99. Thats how we're doing it, as stated in my 3rd post. I've been gathering as much info as I can the past 2 days. Anyone else?
Old Feb 20, 2002 | 08:34 AM
Matt98SS's Avatar
I have a JAZ catch can i have had sitting around for months on end to do the same thing. it should work just fine. really not much different than using filters inline...just the filters you have to replace all the time.
Old Feb 20, 2002 | 10:23 AM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
I have been running two inline fuel filters, the glass kind you can see thru, and they do catch oil.
Old Feb 20, 2002 | 01:37 PM
WhiteDiamond's Avatar
I also made a catch can of sorts using some fuel filters. I left the system fully connected, but just added the area for the oil to accumulate in a see through housing. It worked pretty well and proved the PCV was a problem on my car. I eventually did the "machining" in the engine valley and went with the LS6 system.
Todd
