Head bolt questions, ordered wrong ones.
Old Jan 4, 2007 | 02:34 PM
Lurius's Avatar
Default Head bolt questions, ordered wrong ones.
Well I got my box from summit racing today, along with the ARP head bolts. I think I must have ordered the wrong head bolts.
ARP part #: 234-3701
Summit's website says these fit the 6.0, 4.8, and 5.3 engines but these just dotn seem to be the right ones, maybe just cause im a noob.
Could someone please confirm wether these are the correct bolts for me?
The block is an 01-04ish 6.0 block and heads are 317 castings from an 04.
Thanks guys!
Michael
Old Jan 4, 2007 | 06:11 PM
slow trap's Avatar
i think the ones you need are 234-4316.those are the ones for an ls1/ls6 or a pre 2004 ish 6.0. i can't remember the part number for the bolts but my block was a newer one and i myself had the wrong bolts,i needed the ones for a newer block
Old Jan 4, 2007 | 06:18 PM
Lurius's Avatar
What really confused me was that when I checked the part # on summit it says that these are the same bolts used for heads on like 1956+ motors.. I think maybe they are mislabeled or something.. Either way I think if I cany get an answer here tonight i'll call up summit tommorow and ask them to check for me. Wouldent be the first time they had a part mislabeled.. My column shifter gauge housing was completely wrong year, made for 99-02, not for the 03+ yet was labled as 99-present.
Thanks,
Lurius
Old Jan 4, 2007 | 06:19 PM
Lurius's Avatar
Those are the studs, im just looking for the bolts now, I dont think i'lkl be making enough power to worry about requiring studs just yet, and cant justify the 110$ extra for them at the moment.
-Lurius
Old Jan 4, 2007 | 06:24 PM
smask04C5's Avatar
I had the same problem on my 04 vette. ended up ordering 234-4317 pro series studs. In 2004, gm changed the studs to equal length. If your car is 2003 or older, you need to order multi length studs or bolts.
Old Jan 4, 2007 | 06:32 PM
smask04C5's Avatar
234-3701 are lt1 cylinder head bolts. definately a misorder. try 134-3609 ls1 unequal length bolts through 2003.
Old Jan 4, 2007 | 06:38 PM
Lurius's Avatar
Thanks a bunch guys, I think i'll go outside with some wire and find out wether I need equal or odd lenghts.
Looks like i'll be mailing a box back to summit. Not a big deal, motor isnt finished yet(obviously )
-Lurius
UPDATE: They are unequal lenghts lol. Thanks again guys, going to go ahead and order the new ones, then mail these back. Yall have been a great help!
Old Jan 4, 2007 | 06:48 PM
mrr23's Avatar
yep, those are for the old GEN I and LTx motors.
ARP234-3701
here you go
ARP134-3609
2004-up
ARP134-3610
Old Jan 4, 2007 | 06:59 PM
Doc99SS's Avatar
My ARP head bolts that I purchased from Summit Racing are labeled 134-3609,, these are for an LS1 engine.
Old Jan 4, 2007 | 07:22 PM
Lurius's Avatar
Thanks again guys, glad to have people to help me out when I get the stupids.
-Lurius
