cam and heads
Old Feb 22, 2002 | 01:58 PM
BIGSAM99Z's Avatar
Default cam and heads
I'm new the this board, and new to the LS1 game.My question is how much sence does it make to do a cam change with stock heads? I'm the previous owner of a lt1Z and most of the best cams wouldn't work with the stock heads. Is there decent cams that make good hp w/stock ls1 heads. I would appreciate any and all responces,thank u.
Old Feb 22, 2002 | 02:16 PM
AgaveCorvette's Avatar
Default Re: cam and heads
[quote]Originally posted by samiamsad99z:
<strong>I'm new the this board, and new to the LS1 game.My question is how much sence does it make to do a cam change with stock heads? I'm the previous owner of a lt1Z and most of the best cams wouldn't work with the stock heads. Is there decent cams that make good hp w/stock ls1 heads. I would appreciate any and all responces,thank u.</strong><hr></blockquote>
An MTI T1 cam will work well with stock heads. You will make more power with ported heads, of course.
You will enjoy the LS1 cam swap.. it's very easy and you'll get good gains from it.
Old Feb 22, 2002 | 02:25 PM
BIGSAM99Z's Avatar
Thanks for the info. Hows the idle with that cam. If you happen to know.
Old Feb 22, 2002 | 02:28 PM
2000 Camaro SS's Avatar
SMOR info foU
https://ls1tech.com/ubb/cgi-bin/ulti...c&f=1&t=000045
Old Feb 22, 2002 | 02:30 PM
<strong>Thanks for the info. Hows the idle with that cam. If you happen to know.</strong><hr></blockquote>
Slightly rough. Will idle fine in an M6, and "decently" in an A4. Any cam will see more gains with computer reprogramming.
Old Feb 22, 2002 | 02:55 PM
BIGSAM99Z's Avatar
Thanks, I don't mind a little rough idle. How about on the spray, I have 125 horse dry system.
sorry so many questions,but I just bought the car a month ago. 99 A4 with 19,300 miles on it. Getting very antsy to go fastet. thanks
Old Feb 22, 2002 | 03:08 PM
<strong>Thanks, I don't mind a little rough idle. How about on the spray, I have 125 horse dry system.
sorry so many questions,but I just bought the car a month ago. 99 A4 with 19,300 miles on it. Getting very antsy to go fastet. thanks</strong><hr></blockquote>
I'd go with a split pattern cam on the spray if you want to see the best numbers on spray. Ask some of the nitrous guys what they are running.
[ February 22, 2002: Message edited by: AgaveCorvette ]</p>
Old Feb 22, 2002 | 03:10 PM
BIGSAM99Z's Avatar
good info thanks.
