Is this a 'normal' problem??
Old Feb 22, 2002 | 02:48 PM
nbm99ta's Avatar
Default Is this a 'normal' problem??
I just got my 99 TA 3 days ago. It's a stock A4 car. Well I raced this guy on the way to work this morning. I punched it from the stoplight and right before it shifted into second gear, it hit the rev limiter, then shifted. I still won the race, tho.
Is it normal for the car to hit the rev limiter? Or is that caused my transmission slippage while it's shifting?
Old Feb 22, 2002 | 03:35 PM
mach1's Avatar
Default Re: Is this a 'normal' problem??
mine does that sometimes, you may want to check your tranny fluid...
Old Feb 22, 2002 | 03:41 PM
AgaveCorvette's Avatar
tranny fluid. Might want to pull the pan and change the filter while you're at it.
Old Feb 22, 2002 | 05:06 PM
nbm99ta's Avatar
[quote]Originally posted by AgaveCorvette:
<strong>tranny fluid. Might want to pull the pan and change the filter while you're at it.</strong><hr></blockquote>
Ya, I think that would be a good idea. I need to change the oil too anyways.
