Cam install
Old Feb 24, 2002 | 01:00 PM
Nine Ball's Avatar
LS1Tech Co-Founder
Default Re: Cam install
Have you dynoed the car yet? What kind of numbers is it putting down with the current setup? That info is somewhat important for us to determine if you are not running at full potential and even require a cam swap.
BTW, LS1Tech.com is hosting a dyno-day at MTI next Saturday (March 2nd).
Tony
Old Feb 24, 2002 | 04:20 PM
RacerZ's Avatar
[quote]Originally posted by Nine Ball:
<strong>Have you dynoed the car yet? What kind of numbers is it putting down with the current setup? That info is somewhat important for us to determine if you are not running at full potential and even require a cam swap.
Tony</strong><hr></blockquote>
I just dynoed at MTI yesterday and it cam up 360hp & 363 of torq. I dynoed 363hp last time & that was before the LS6 intake and computer reprograming.
Old Feb 24, 2002 | 08:25 PM
227Hawk's Avatar
IMHO Visit a tuner, do some A-tap
or the very least WB 02 readings.
You shouldn't have lost HP,get some
readings. <img src="graemlins/gr_judge.gif" border="0" alt="[judgement]" />
Old Feb 24, 2002 | 08:35 PM
BIGBOS's Avatar
I would suggest getting a bigger cam, if you even stepped up to a T1 you would see 400rwhp easily with programming... <img src="gr_stretch.gif" border="0">
Old Feb 24, 2002 | 08:56 PM
227Hawk's Avatar
BIGBOS beter look at that F1 system at
the end of sign.N20 doesn't like a really
large cam. Yes it will run great with one
but your just adding more to equation.
This is mt .02,So don't burn me <img src="gr_images/icons/wink.gif" border="0">
Old Feb 24, 2002 | 10:42 PM
RacerZ's Avatar
[quote]Originally posted by las vegas hawk:
<strong>BIGBOS beter look at that F1 system at
This is mt .02,So don't burn me <img src="gr_images/icons/wink.gif" border="0"> </strong><hr></blockquote>
The sales guy at MTI wants to put the C1 cam in the car. Isn't that a pretty big cam? or should I go smaller?
Old Feb 25, 2002 | 12:39 AM
RacerZ's Avatar
Default Cam install
I need a bigger cam. Any suggestions? also who is resonable priced around the Houston area to install it? My cam specs right now <img src="images/icons/confused.gif" border="0"> Its a mild cam is all I know he did give me some numbers I think 216 or 218 & 530( don't know if that helped)
Old Feb 25, 2002 | 08:40 AM
Matt98SS's Avatar
[quote]Originally posted by RacerZ:
<strong>
The sales guy at MTI wants to put the C1 cam in the car. Isn't that a pretty big cam? or should I go smaller?</strong><hr></blockquote>
well you say you wanted a bigger cam right? and you have a 216 or 218. The C1 is only 222/222 duration, not much bigger really. it will give you a bit more HP but possibly not worth the swap if money is a concern.
then you also have to think about springs. if you cam now only has 530 lift then the springs may not be suitable for the C1 as its like 561 or something around there.
I think there may be something wrong somewhere else though
Old Feb 25, 2002 | 11:15 AM
jmX's Avatar
jmX
[quote]Originally posted by BIGBOS:
<strong>I would suggest getting a bigger cam, if you even stepped up to a T1 you would see 400rwhp easily with programming... <img src="gr_stretch.gif" border="0"> </strong><hr></blockquote>
That is just flat out misinformation. The T1 would give him only a few hp over what the 218'ish cam he has...if he's only doing 360 through a 2001 intake, headers, stage 2 heads, and cam, the problem lies somewhere else. I've never personally seen an issue where tuning takes 40rwhp from a car, but I guess anything is possible....
The redneck theory is that the bigger the cam the better, but it certainly wasnt the case on my car.
Old Feb 25, 2002 | 06:05 PM
227Hawk's Avatar
My feelings, something else is not set-up
right.That larger exhaust cam is usually
a plus on N20.(Helps clear cylinder)I would
do some logs and WB20 runs before ever
attempting cam change <img src="gr_grin.gif" border="0">
Old Feb 25, 2002 | 07:43 PM
RacerZ's Avatar
My friend seems to think the heads aren't flowing. I hope there actually ported heads!
Old Feb 25, 2002 | 08:06 PM
227Hawk's Avatar
Time to do some A-tap,you have any
vaccum leaks? Those heads should
flow great.A-tap would be way to
check out alot of things .02
Old Feb 25, 2002 | 08:35 PM
Toxic Texan's Avatar
What do you have exhaust wise? Maybe your restriction is there.
Old Feb 25, 2002 | 09:31 PM
RacerZ's Avatar
I have a Borla exhuast system with the wide open plate on it.
