Head and cam install, then...
Old Jan 5, 2007 | 11:03 PM
seabirdak's Avatar
Default Head and cam install, then...
Is it possible to add a supercharger or STS turbo kit? Or will the compression ratio be too high?
Old Jan 5, 2007 | 11:09 PM
Mssingkid's Avatar
Well you can do heads and cam on a forced induction motor. You just have to pay special care to the SCR. The magic number for boosted cars seems to be 8.5, the closer you get the better you'll be. With some nice heads you can get more power out of a turbo or supercharger @ a lower psi.
Old Jan 5, 2007 | 11:25 PM
seabirdak's Avatar
Ah I see so its one or the other, or build up a motor with upgraded heads and low compression for the S/C makes sense.
Old Jan 5, 2007 | 11:47 PM
massls1guy's Avatar
Fyi, n00b here. I agree on SCR. But cam selection is important too. I think a mild cam is better for boost. You don't want too much duration on the cam - the PSI will bleed out.
Old Jan 6, 2007 | 12:07 AM
JRracing's Avatar
There is a guy in the dyno section. Has a 224/224 and 6.0 heads with ati d1sc hittin 600rwhp.
Plan it right.
Old Jan 6, 2007 | 01:37 AM
Dustin 98TA's Avatar
Not necessarily, as long as the LSA is kept around 114 or so. Ive found with boost, the bigger the cam, the more power it will make. Driveability may suffer, and it wont be too friendly as a daily driver, but it will make lots of power.
Old Jan 6, 2007 | 02:03 AM
seabirdak's Avatar
It's all making sense now, thanks for the feed back everyone.
Old Jan 6, 2007 | 04:45 PM
SLO C5's Avatar
Default H/C with boost
Yeah, most people that do heads and cam end up with a SCR of around 11.0:1, but they plan to stay NA at that point.
If you're going to do H/C and want to do forced induction later, then you definitely want to be in he 8-9 range.
