Lifters
Old Jan 6, 2007 | 12:29 PM
00hawk120's Avatar
Default Lifters
im in the process of changing heads on my car and decided while i was at it to go ahead and change the lifters while i was there. what lifters should i get. I dont know much about them as far was whats good or bad?
Old Jan 6, 2007 | 01:28 PM
dame's Avatar
I was going to get the morels........ but instead I put the new gm cts-v lifter in. I honestly dont think you could go wrong with either one of those..... the morels are about $500 but ARE rebuildable though. the upgraded gm lifter i think was about $250
scoggin has them.
Old Jan 6, 2007 | 01:43 PM
LETHL_SS's Avatar
It depends on your goals.... If you plan on an all out setup or spin 7K or above go with the Morel/Lunati lifters. If not, any other will be fine but I'd def stay away from Comp R lifters.
Old Jan 6, 2007 | 02:53 PM
Josh's Avatar
I opted for the OEM replacements since my car only sees street duty. I believe the LS1 replacements are used across the LSx line, including the LS7, so they should be adequate for most peoples' needs. And at $100, they're more affordable than aftermarket lifters.
Josh
Old Jan 6, 2007 | 02:56 PM
00hawk120's Avatar
well if the OEM replacements are good is there any real need for me to change mine out. i was only going to do it because i already have it apart. my stockers have around 80,000 miles on them.
Old Jan 6, 2007 | 03:33 PM
blkbird's Avatar
I replaced mine at 100k with stock replacements for piece on mind. Whenn i removed the old ones they looked like a couple had minor wear to them..... Its better that having them fail down the road......
Old Jan 7, 2007 | 02:00 PM
Marc '99T/A's Avatar
Would Comp 850-16's hold up to LSK lobes with .639 lift? Or should I look at the CTS-V or LS7 lifters? I don't plan on spinning the engine over 6500.
Sorry bout the hawk.
Old Jan 7, 2007 | 03:07 PM
HAMRHEAD's Avatar
Morels are great but not really necessary. Comp 850's will work fine and give you piece of mind that you have a fresh set of lifters. I replaced all mine as well when I did a H/C swap since it is the easiest time to do it.
Old Jan 7, 2007 | 03:17 PM
Camaro99SS's Avatar
Originally Posted by dame
but instead I put the new gm cts-v lifter in. the upgraded gm lifter i think was about $250
scoggin has them.
I don't recall seeing a special "upgraded" lifter for CTS-V's. If there was, why did GM stick with the same lifter they've used since 1987 for the LS7 Z06 that has a factory redline of 7000 and carries a warranty?
Jason
Old Jan 7, 2007 | 03:22 PM
bryced1's Avatar
hes refering to the cts-v R lifters i belive
Old Jan 7, 2007 | 03:38 PM
CHRIZ28's Avatar
The LS7 lifters I bought for my car were different than the factory ones I pulled out, I mean, I don't know if they're exactly the same inside or not, but they definatly look different. Seems like there's more material around the roller and more contact between block and lifter. The machined part around the lifter is longer. Dunno?? I just opted for those for the same reason you said, the LS7 spins 7K and has a factory warranty, good enough for my car...
Chris
