Ported LS1 Heads......Lots of Pics
Also, I have pictures of several of the aftermarket 8mm LS1 valves compared to stock and pictures of what we are talking about by valve shrouding. So hopefully the pictures will assist in educating people about modifying cylinder heads and help them make more informed buying decisions.
The first few pics are the 5.3 heads that I recently finished porting for a good friend of mine. You can see what they look like compared to stock and why porting is an art. Before you ask, they're not milled yet, don't have a fresh valve job, and have not been flowed tested yet.
Ported vs Stock Exaust
Ported Intake
Ported Intake 2
Ported Exaust 1
Ported Exaust 2
Ported Exaust 3
The next couple pictures are the chambers of the ported 5.3 head, a stock 5.3 head, and an LS1 head with 2.02 1.57 valves hung open at about .400" lift. Valves tend to be shrouded, thus a flow loss, when the chamber wall or the cylinder wall in the bore is too close to the valve. The polished chamber with the aftermarket valves is about how much clearance you want around the valves to avoid shrouding them. And the chamber wall has been widened all the way to the gasket line for an LS1 so opening them up anymore on a stock bore won't do you anygood. This probably makes you wonder why people go bigger than 2.02 and 1.57 huh?
Polished 5.3 Chamber
Polished 5.3 w/2.02 1.57 Valves
Stock 5.3 w/2.02 1.57 Valves
Stock 5.7 w/2.02 1.57 Valves
Notice how the valves almost touch the chamber wall in the stock 5.3 heads. You can see how much the chamber wall needs widened to prevent shrouding. That's why the "X" option or whatever each shop calls it, costs more. But in my opinion, it is worth it for the increased compression.
You can also see in the pics how the 5.3 chamber is shaped differently than the 5.7 chamber. Compare the polished 5.3 chamber to the stock 5.7, on the exaust side and you can see how the exaust side is more closed and how dramatic the tumble ramp is on the 5.3 heads.
Also notice in the polished 5.3 chamber how I rounded the spark plug guide boss which should reduce turbulence.
I would have posted pictures of stock intake and exaust ports etc. but they didn't come out very good on my camera. It's pretty tough to see anything in those dark ports.
The next two pictures are 8mm LS1 valves. From left to right, they are Ferrea, Rev, a Manley version, and a stock 98/99 and then 00+. It's pretty amazing how different the valves really are. In factory form I like the Ferrea's because of the smaller seat width and gentle radius below the seat. They also have a larger margin which will produce a little higher compression compared to the others. Notice how all three aftermarket valves have undercut stems. My opinion is that the aftermarket valves increase flow, not because of their larger size, but because of their better shape. Look at how pathetic the 98/99 exaust valve is. The stem is fat just above the tulip and it leaves a lot to be desired for a good radius from the seat. Look closely and you can see how the valves are tuliped more/less than the others. I think it would take a lot of flow bench time to figure out which valve is better for the port. And there are so many combinations of back cuts that are possible....who knows which valve could be the best.
LS1 Intake Valves
LS1 Exaust Valves
Well I just thought I would share these pictures. Maybe a light bulb came on for a few people that finally understood what somebody else was talking about.
Questions or Comments?
[ January 26, 2002: Message edited by: Jantzer98SS ]</p>
Ryan
[ January 26, 2002: Message edited by: The Underdog ]</p>
Doug
02BlackWS6:
Generally you don't want to polish the intake ports because the tendancy is for gas to pool up in the ports and get suspended from the air, but it's not so much a problem with a fuel injector that is pointed straight at the back of the valve.
ProModTA:
Actually the LS1 valves aren't THAT bad. I've seen a lot worse. But, GM does make some great valves too. LS6 Sodium Filled!
Scott
