New head gaskets
Old Feb 21, 2002 | 09:11 PM
y2khawk's Avatar
Default New head gaskets
Looks like you can get a decent factory gasket these days <img src="gr_stretch.gif" border="0">
We'll see how they do
Old Feb 22, 2002 | 12:15 AM
Reckless's Avatar
Super Moderator
Default Re: New head gaskets
So where did these come from and how much $$$ ?
Old Feb 22, 2002 | 12:26 AM
Jason99T/A's Avatar
I can shift faster than you.
Looks like a 2002 GM factory head gasket for the LS1. <img src="gr_grin.gif" border="0"> I was shocked the first time I saw them.
[ February 22, 2002: Message edited by: Jason99T/A ]</p>
Old Feb 22, 2002 | 06:55 AM
y2khawk's Avatar
[quote]Originally posted by Jason99T/A:
<strong>Looks like a 2002 GM factory head gasket for the LS1. <img src="gr_grin.gif" border="0"> I was shocked the first time I saw them.
[ February 22, 2002: Message edited by: Jason99T/A ]</strong><hr></blockquote>
Could be <img src="gr_stretch.gif" border="0">
This one is actually for a 4" bore. 6.0L gaskets. #12569365
But the same style is available for the 5.7L and the 4.8/5.3L
I'll dig up those part numbers when i get to work.
[ February 22, 2002: Message edited by: y2khawk ]</p>
Old Feb 22, 2002 | 08:36 AM
Aircooled's Avatar
What is the actual measured bore I.D.?
What 3 gaskets are you comparing in the second picture?
Steve
Old Feb 22, 2002 | 08:58 AM
y2khawk's Avatar
I will measure the bore tonight, but i put up against my 6.0L heads to compare. It's about .1" bigger all the way around than the chamber. But i will confirm the actual diamter.
Those aren't 3 seperate gaskets. The gasket is a 3 layer metal setup. Main compresion seal is made by the inner layer, and the coolant passage seal is made by the spring steel/"rubber coating" on the outer layers. They are interchangeable between sides.
Old Feb 22, 2002 | 10:02 AM
Jay 95WS6's Avatar
guys don't get all revved up about these gaskets GM doesn't sell individual gaskets now. The head gaskets now come in a kit that includes the bolts and valve cover gaskets etc. so the cost is substantially higher.
Jay
Old Feb 22, 2002 | 10:54 AM
AgaveCorvette's Avatar
[quote]Originally posted by Jay 95WS6:
<strong>guys don't get all revved up about these gaskets GM doesn't sell individual gaskets now. The head gaskets now come in a kit that includes the bolts and valve cover gaskets etc. so the cost is substantially higher.
Jay</strong><hr></blockquote>
so? You need the bolts, anyway.
Old Feb 22, 2002 | 11:39 AM
RUQWIKR's Avatar
You can get them in a kit with all the needed gaskets and headbolts, etc., or individually. I believe the PN for the LS1 head gasket (one) is 12573949.
Old Feb 22, 2002 | 04:09 PM
Go Texas Tech's Avatar
I recently purchased the '02 head gaskets and head bolts too. They were sold separately. <img src="images/icons/confused.gif" border="0">
Old Feb 22, 2002 | 05:56 PM
Rocco's Avatar
Maybe I can use these on my big bore motor?
Please let us know what the exact size is.
Old Feb 22, 2002 | 06:06 PM
A70camaro's Avatar
Interested in those part numbers for individual gaskets and the whole kit
for 5.6 liter
Old Feb 22, 2002 | 06:40 PM
Tin Indian's Avatar
[Quote] "You can get them in a kit with all the needed gaskets and headbolts, etc., or individually. I believe the PN for the LS1 head gasket (one) is 12573949".
[Quote] "And yes, the 5.7 bore P/N is correct 12573949".
_____________________________________________
I am confused here. The P/N for the right and left stock LS1 head gasket is P/N 12558809 & 12558810. I understand the Rt and Lft sides are [not] interchangable. These part numbers are also in the LS1.Com database.
Why are my part numbers different from what you folks are posting?
Thanks,
Ron
Old Feb 22, 2002 | 06:51 PM
y2khawk's Avatar
new gaskets, not side specific.
The new ones are 3 layer metal instead of the old graphoil <img src="gr_stretch.gif" border="0">
Old Feb 22, 2002 | 07:11 PM
Tin Indian's Avatar
y2khawk...
Thanks for the reply.
So, what I understand is that P/N 12573949 will get you one 3 layer stock LS1 head gasket, or will this P/N get you a pair of them?
Right a left side of this new gasket is interchangable
Is this new gasket now installed from the factory on all 2002 LS1s or is this a newly released GM Performance Part (not used as a factory installed part)?
Ron,
Old Feb 22, 2002 | 08:20 PM
y2khawk's Avatar
factory '02
it's only one gasket
and it is interchangeable side to side
Old Feb 22, 2002 | 09:08 PM
A70camaro's Avatar
Not too expensive either
Just got a price from gmpartsdirect.com
even with there crazy shipping and handling charges they come out to be around $35 for a pair
GM list is $20 each
Can somebody get hold of the "kit" part number
Old Feb 22, 2002 | 09:42 PM
Tin Indian's Avatar
Thanks alot..... Well I guess there is no reason to put the stock 98 graphite gaskets in there anymore. Thanks for posting info on these updated gaskets.
However, to play the other side of the coin, I cant think of anyone that has blown the stock head gaskets on your typical heads/cam/headers car (as long as no spray/no boost)
Ron,
Old Feb 22, 2002 | 10:02 PM
Jay 95WS6's Avatar
the 3949 gasket has been superceeded this week to the gasket kit as well as the 8809 and 8810 as well just trying to let you guys know and i have several of the "new" gasket kits in stock
Jay
Old Feb 22, 2002 | 10:23 PM
Tin Indian's Avatar
Jay,
So you are saying; The new head gaskets cannot be ordered separatly?
If they come in a kit, what the kits P/N and price?
What is exactly in the kit? Both head gaskets, all M-11 short, all M-11 long, and all M-8 head bolts?
Thanks Jay,
Ron Larson
