Base circle difference between Lunati B1/T1 and TR224?
Old Feb 25, 2002 | 09:12 PM
Patrick G's Avatar
LS1 Tech Administrator
Default Base circle difference between Lunati B1/T1 and TR224?
I just swapped cams from a Lunati 221/224 to a Thunder Racing TR224/224. I had my plunger depth set at .010-.020" on the old cam, but the valves clatter a bunch with the TR 224 cam. I removed .020" in shims under the rockers and the clatter improved, but the valve are still tapping more than they should. Is the TR 224 that much smaller in base circle compared to my old Lunati?. I've got .035" more shim under the rockers. My pushrods are 7.350". My heads have been milled around .040-.050"...that's why the rockers were shimmed. maybe the shorter pushrods are all I need. Help please!
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2022 Cadillac Escalade 6.2L A10 S&B CAI, Corsa catback.
2023 Corvette 3LT Z51 soon to be modified.
Custom LSX tuning in person or via email press here.
Old Feb 25, 2002 | 09:13 PM
jmX's Avatar
jmX
Default Re: Base circle difference between Lunati B1/T1 and TR224?
Go measure your B1/T1. My TR224 came in at 1.493 I beleive. How many turns past zero lash did you have to go before the rocker bolt wanted to stop?
Old Feb 25, 2002 | 09:19 PM
Patrick G's Avatar
JMX,
The stem heights on the valves are not consistent enough. On my exhaust valves, they only needed a half turn past zero lash. That's why I took .020" of shim out. Maybe I need to have more plunger depth.
__________________
Old Feb 25, 2002 | 09:41 PM
Jason99T/A's Avatar
I can shift faster than you.
I don't know if this will help any, but here goes:
On Chris's car (443rwhp GTP stg 2 heads/TR224 cam), we used stock length hardened pushrods (7.400). The 5.3l heads were milled 15 thousandths.
What lifters are you using?
Old Feb 25, 2002 | 09:52 PM
Patrick G's Avatar
I'm still using the stock lifters Jason (but they're my 2nd set).
__________________
Old Feb 25, 2002 | 10:23 PM
jmX's Avatar
jmX
As long as you have at least 10thou preload and less than say, 100thou, you should be fine (stock lifters seem pretty forgiving). The cam is just gonna be a little noisier since it has fairly steep ramps.
Either way, I use 7.400" pushrods for my TR224, and used 7.350" for my previous cam (224/230 .540)
