Who can tune my car?
Old 02-26-2002, 07:03 AM
2000 Camaro SS's Avatar
Default Who can tune my car?
I live in Iowa City (Yuck! that gast'a suck!) Any, after I get done with my motor who can I take my car to to tune it? I would suppose Chacago may be closest?
Would this be money well spent or can I do the same using my A Tap & MAFT?
I want it tuned for running nitrous (Not sure if it makes a differnce).
P&P Heads, Ferrea Competition Plus Valves, Lunati 221/224 .558 .560@114, CC 941, NX-N2O, Purge, 75mm MAS, pulleys, 160 deg, NGK T6, TB By-Pass, Taylor Wires, MAFT, Bosh fuel pump, AutoTap, K&N Filter, Direct Flow, Edelbrock STB, Free Mods, HPP3, Shift Light, Spohn: Torque Arm, LCA, Panhard Bar, CA Relo-Brackets, KB DD, SLP LT, SLP Y, Random Tech High Flow Cats, Cut Outs, Line Locks, Mcleod Twin, Strange 12 bolt, Spool, 4:10's, Slicks, W.R.Roll Bar, RCI Belts, A-Tap
[ February 26, 2002: Message edited by: 2000 Camaro SS ]</p>
Old 02-26-2002, 09:42 AM
LS1Tech Co-Founder
Pro Stock John's Avatar
Received 1,174 Likes on 763 Posts
Default Re: Who can tune my car?
One of our sponors is Speed Inc.
They have a dyno now with a wideband.
I'm bringing my car other there and Brian from BV Performance will revise my tuning.
You may want to talk to Brian and get his thoughts. Maybe you should shoot for a more conservative amount of timing and a richer A/F ratio.
BTW, I did 435rwhp last time and have changed a few things to hopefully get the car up to 470rwhp or higher.
www.bvperformance.com
Old 02-26-2002, 03:16 PM
ForbesSS's Avatar
There are a couple of excellent shops around the chicago area that have wide band tuning. My humble opinion, don't waste time w/ MAFT. I only gained 10 hp...and that was in conjunction with the wide band dyno. Custom tuning can net quite a bit more from what I've read. I'll let you know...Speed Inc is doing mine next week.
Old 02-26-2002, 03:28 PM
Sorry for the ignorance here....I am assuming that I need to bring my car in to get custom tuned? Am I right? It seems this would be far more accurate. I also already have a MAFT on my car I won't have to buy one. ForbesSS This would still be beneficial at the track for minor tuning am I right?
John I'll be giving them a call when I closer to time to do it. Until then I'm still learning all I can. I'm about to order a WolfeRaceCraft Sway Bar but I need to talk to them to custom make it as my new rear end is shortend.
Old 02-26-2002, 04:57 PM
LS1Tech Co-Founder
You can come out here to Chi-town and get it dynotuned.
