Broke 918 spring!
Old Feb 27, 2002 | 05:56 PM
CinderSS's Avatar
Default Broke 918 spring!
Well I finally tore down my car to find the broken spring on the #1 cylender <img src="gr_sad.gif" border="0"> . It made no loud noise at idle. It Just had a rough idle, loss of power, flashing ses light and a p0300 code. hopefully I don't have a bent valve. Oh well new springs comming! <img src="graemlins/gr_chug.gif" border="0" alt="[chug]" />
[ February 27, 2002: Message edited by: CinderSS ]</p>
Old Feb 27, 2002 | 07:11 PM
LS1x2's Avatar
Formerly 4mulaJoe
Default Re: Broke 918 spring!
what are your cam specs? How high do you rev it?
Old Feb 27, 2002 | 07:20 PM
mmiller's Avatar
Texas Director
and how long had the 918's been on your car?
Old Feb 27, 2002 | 07:40 PM
BIGBOS's Avatar
yea I broke a 941 once..... <img src="graemlins/gr_barf.gif" border="0" alt="[barf]" />
not good..... <img src="graemlins/fluffy.gif" border="0" alt="[Fluffy]" />
Old Feb 27, 2002 | 08:04 PM
CinderSS's Avatar
It's the 224 cam with 114ls. I only have a little over 3000 miles on the new engine and I'm at stock rev limiter. I cannot tell you exactly when it happened, but I have a feeling it happened at the track when my clutch slipped and I nailed the rev limiter. I have yet to hear of anyone else having problems with these springs...mabey it was just a bad spring. <img src="images/icons/rolleyes.gif" border="0"> Oh well; you got to pay to play!
Old Feb 27, 2002 | 09:25 PM
SteveD's Avatar
I hope that it was a freak thing. I just installed these and I am hoping I don't have any trouble with them.
Old Feb 27, 2002 | 09:44 PM
iLLuSiON's Avatar
I've had the 918's with my Thunder 224 114lsa on for about 4500 miles now. I've hit my 6800 rev limiter probably 5 times now and I'm still running okay. I have the stock retainers.
Old Feb 27, 2002 | 10:32 PM
brendon's Avatar
So you had no noise what so ever? Wow, I have the same cam only it the 112 lsa, I rev it up to 6000 r's often, and I missed a shift once but not to bad. I think that I might have to pull my covers and see whats going on in there, I am suprised that you didn't notice it prior to pulling the valve coves, and you are also lucky that nice little valve didn't feeling like dropping down and going for an expensive ride <img src="graemlins/gr_guns.gif" border="0" alt="[guns]" />
Old Feb 27, 2002 | 10:44 PM
jmX's Avatar
jmX
Sucks, first time I've heard of a 918 breaking. All the more glad I went with the larger double springs. <img src="gr_eek2.gif" border="0">
Old Feb 27, 2002 | 11:11 PM
SSBoy's Avatar
this is weird that these comp springs are always breaking. is it only 6M guys that break these springs due to overreving??
ive got almost 10K miles on my comp 941 SPRINGS
WITH my TR-224 cam and my old Comp 212/218 cam and haven't had a single break yet! should i knock on wood? hmm...
<img src="images/icons/confused.gif" border="0">
Old Feb 28, 2002 | 07:57 AM
RPM WS6's Avatar
LS1Tech Administrator
Community Influencer
WOW! I'm sad to hear about this <img src="gr_sad.gif" border="0"> I thought the 918s were going to be the "wonder springs"...
Were you using the 772 ti retainers or stock?
Old Feb 28, 2002 | 08:00 AM
Matt98SS's Avatar
i still think the 918s are the best option out there for a single spring. they will be on my new heads
I have the 941s currently been running them for I would say over 40k miles maybe 50k. no problems
Old Feb 28, 2002 | 09:38 AM
Fireball's Avatar
wow...are we going to have a rash of problems with 918s now???
I'm glad I spent the $$$ for a double conversion, but I thought the 918 was the key <img src="gr_sad.gif" border="0">
Old Feb 28, 2002 | 09:45 AM
RPM WS6's Avatar
I bought a set of 918s and 772 retainers back in December for a cam that I still haven’t installed. Hope they don’t break... <img src="gr_sad.gif" border="0">
Old Feb 28, 2002 | 10:30 AM
mattf2's Avatar
Has anyone installed the ZO6 springs w/ aftermarket cam? I know they're good to 66-6800.
Old Feb 28, 2002 | 10:32 AM
RPM WS6's Avatar
[quote]Originally posted by mattf2:
<strong>Has anyone installed the ZO6 springs w/ aftermarket cam? I know they're good to 66-6800.</strong><hr></blockquote>
I think those springs are only good up to .525 lift or so. Most of us have a lot more lift than that...
Old Feb 28, 2002 | 02:05 PM
Chris Spiess's Avatar
[quote]Originally posted by RPM WS6:
<strong>
I think those springs are only good up to .525 lift or so. Most of us have a lot more lift than that...</strong><hr></blockquote>
The 2002 springs will take more lift than that, the 2002 LS6 cam is 0.551/0.547
Old Feb 28, 2002 | 03:21 PM
Brains's Avatar
Wow, the first 918 spring to break <img src="gr_stretch.gif" border="0"> Generally broken springs are due to incorrect application or incorrect installation. I know a LOT of 941 springs broke because the retainers didn't fit them properly.. Some people don't pay enough attention when installing springs, and get them seated a little crooked, and they break. There's a lot of reasons springs break, and the last one is from the material itself failing.
I'm running 26915's with my CC 221/227 .561/.569 114 since last June (over 13k miles so far) with a 7000 RPM rev limit, and all is well so far! (knocking on wood I did the install right!)
<img src="graemlins/formula.gif" border="0" alt="[Pontiac]" />
Old Feb 28, 2002 | 03:51 PM
DANS LS1's Avatar
thats got to suck..
Old Feb 28, 2002 | 04:28 PM
CinderSS's Avatar
I truly think that it was just a bumb spring. That is why I ordered more 918's to replace the broke one. So far I am the only one to break one...that I have heard of. So that alone should tell you that their doing pretty well. It could have been alot worse. Later
