Motor is back together, runs like crap...
Old Mar 4, 2002 | 06:59 PM
The Juggernaut's Avatar
Default Re: Motor is back together, runs like crap...
I'm far from an expert.
broken valve spring?(excessive valvetrain noise)
PCM screwed up?
I'd pull the valve covers and take a look.
Old Mar 4, 2002 | 07:13 PM
PhantomTA's Avatar
Pulled the covers, everything appears to be fine
<img src="gr_stretch.gif" border="0">
Old Mar 4, 2002 | 07:46 PM
zombiedude's Avatar
Low vaccum maybe why the MAF got a code. Gas coming out of tail pipe? Black smoke or dripping gas. Are injecters pulsing or staying on? That's the only code? Is compression good? Just some ideas to look at. hope this helps. <img src="gr_images/icons/wink.gif" border="0">
Old Mar 4, 2002 | 07:51 PM
zombiedude's Avatar
Also I for got my notes at work but it needs to run before relearn. that keeps u from getting missfrie codes. (new crank). my post way up there is how the computer does it by itself or Tech 2 can do it in seconds.
Old Mar 5, 2002 | 12:29 AM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
"Off a tooth"
BZZZZZT!
You would have bent valves when you started up the motor Dave.
Do you have to give it gas on startup, like half-floored or more, and then it runs really crappy and rich?
Pushrods might be too long. Check lifter preload. What length pushrods are you running? I'm guesssing you should have 7.350's.
Old Mar 5, 2002 | 01:10 PM
blackhawk2000's Avatar
Call Matt.
Old Mar 6, 2002 | 05:59 PM
PhantomTA's Avatar
Thanks for the replies guys.
keep em coming <img src="gr_stretch.gif" border="0">
Old Mar 7, 2002 | 03:20 PM
PhantomTA's Avatar
Okay just got back from seeing the car.
No Maf code now..
Getting only the p300 (random misfire right?)
Car missfires like freaking crazy... but isnt setting a code for it.. the SES doest flash like it would if it had a plug wire off.. but man it sure feels like 4 are off..
Timing is good, INjetor pulswidth is same numbers they were before.. thats good
LT's i had about 0ish
HOWEVER.. ST Trims were -17 - -22 the car loads up like ad and wants to die.
The valvetrain is noisey as hell, Nick A said the new valvetrainer is lighter so it might be quieter.. <img src="images/icons/rolleyes.gif" border="0">
i goin nuts here.. it will only idle on its own for about 2 mins and thats after you change the plugs...
guys?
[ March 07, 2002: Message edited by: PhantomTA ]</p>
Old Mar 7, 2002 | 03:28 PM
LS1Tech Co-Founder
Car is running extremely rich. It's taking out a large amount of fuel.
What air induction do you have?
Use a MAF T to lean it out or something.
Old Mar 7, 2002 | 03:34 PM
PhantomTA's Avatar
John <img src="gr_stretch.gif" border="0">
alredy tried that..
didnt help
like i said i had the LT trims to close to 0.. but the ST were wild like that
weird huh
Old Mar 7, 2002 | 05:00 PM
y2khawk's Avatar
Did they reconnect all the grounds on the back of the driver side head?? <img src="gr_stretch.gif" border="0">
MAP sensor plugged in??
do any mods to the fuel system??
Old Mar 7, 2002 | 05:06 PM
  #32
Patrick G's Avatar
LS1 Tech Administrator
Check to see if your rockers are coming into contact with the valve retainers. This could be bleeding off cylinder pressure and make it missfire like a ****. Lash caps...why? They could be hitting the bottom-side of the rockers. Maybe?
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2022 Cadillac Escalade 6.2L A10 S&B CAI, Corsa catback.
2023 Corvette 3LT Z51 soon to be modified.
Custom LSX tuning in person or via email press here.
Old Mar 7, 2002 | 05:09 PM
  #33
PhantomTA's Avatar
Matt,
all 3 grounds are attached.
Fuel system is the same.. no changed..
As far as i know the map is plugged in..
As far as the lash caps.. I have no idea why!!! NONE..
ARE says use 7.250 pushrods with 8o thou last caps
Old Mar 7, 2002 | 05:12 PM
  #34
Patrick G's Avatar
Please, please, please check the rocker to valve spring clearance just to be safe.
__________________
Old Mar 7, 2002 | 05:17 PM
  #35
y2khawk's Avatar
better yet, run it w/ the valve covers off
I'm serious
Old Mar 7, 2002 | 05:23 PM
  #36
PhantomTA's Avatar
Doublechecked and the rockers are NOT hitting anything.. i just called them, and according to them that was checked and double checked to be safe.
Matt, Map Senser is plugged in
Old Mar 7, 2002 | 06:18 PM
  #37
MIGHTYMOUSE's Avatar
what kind of springs are on the heads? double? if so you need to clearance your 98 valve covers or it will hold open the valves on the 4 corners of the motor.. i would check this reguardless.. it happend to me. <img src="graemlins/gr_barf.gif" border="0" alt="[barf]" />
car ran really bad, much unburned fuel in the exhaust, no codes, terrible idle etc.
email me if you need more info.
