Double Valve Spring?
Old Mar 1, 2002 | 07:47 PM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
Default Re: Double Valve Spring?
Depends on the cam.
I am running a 590 lift ARE/Lunati cam, and Comp Cam 987-16 springs.
Old Mar 1, 2002 | 07:49 PM
Linear Velocity's Avatar
Agreed <img src="gr_grin.gif" border="0"> I'm running 987 Double Springs with my cam, it's a .591 lift.
Old Mar 1, 2002 | 10:15 PM
Sears's Avatar
!Dial-up Director
987s with .561 lift, no valve float or any other problems.
Old Mar 2, 2002 | 12:55 AM
Slammed Vette's Avatar
Default Double Valve Spring?
What springs are the best?????
Old Mar 2, 2002 | 10:41 AM
I'm going to be running a 226/234/114 .554/.575 cam and just want the best parts!!!!I know my cam isn't as big as you guy's.Only going to have this set-up for this summer.408 solid roller going in next winter!!!!!!
Old Mar 2, 2002 | 11:29 AM
VINCE's Avatar
Shorty Director
Many guys run a single spring with that cam.. I run a Crane Double Spring and the problem I ran into was diameter.. 1.46" seems to be too wide to use the stock rocker arms with at 1.8" install height. B4 I chose the spring I did a search on the diameter and I could not find anyone having a clearance issue.. So I had to find out for myself..
