Preload for LS6 lifters?
Old Jan 9, 2007 | 08:40 PM
ArcticZ28's Avatar
Default Preload for LS6 lifters?
I'm gonna be checking PR length this winter while the car is down so I wanted to get an idea for what the preload should be on the stock LS6 lifters. They are pretty new with only 5k miles on them but I'm thinking there is just a little too much ticking going on in the engine bay.
And as a side note, I don't have any bent PR's or anything of the sort. The car runs great, just seeing if I can get a little less tick. If not, no biggie, just gonna check it out for my own personal benefit.
Old Jan 9, 2007 | 09:21 PM
Dan_the_C5_Man's Avatar
From an expert.. https://ls1tech.com/forums/generation-iii-internal-engine/637577-katech-how-check-lifter-preload.html
Old Jan 9, 2007 | 09:57 PM
ArcticZ28's Avatar
Yea, I just saw that thread which made me create this one. I won't be doing it Katech's way. I will be doing it the way Guit's Boy explained. Regardless, I still need to know what preload they work well with.
Old Jan 9, 2007 | 10:12 PM
thehammer69's Avatar
OEM lifters have .150-.200" of travel. Since it is advised to run in the center of travel, I'd shoot for .75" to .100" of Preload.
I also know Tony Mamo recommends .070"-.110" Preload. Maybe it isn't coincidence that two experts recommend close to similar specs.
Hammer
Old Jan 9, 2007 | 10:51 PM
ArcticZ28's Avatar
Thanks for that info hammer. Would it be better to err on the higher or lower number for preload?
Old Jan 9, 2007 | 11:30 PM
i'd probably shoot for close to .075" without going under.
Hammer
Old Jan 9, 2007 | 11:54 PM
PREDATOR-Z's Avatar
I go .080>.110, seems to make things so much quieter.
Old Jan 10, 2007 | 03:07 PM
GuitsBoy's Avatar
Thats what I like too. My stock was .080 and im running .011 over now at .091. Much quieter than when I was at .051 (before milling heads).
Old Jan 10, 2007 | 03:35 PM
JPH's Avatar
JPH
.090 is the magic #, from what i see.
