Cars missing...stumped
Old Jan 12, 2007 | 12:30 AM
BADBOYZ28's Avatar
Default Cars missing...stumped
Car was missing pretty badly under 3k RPM after running around the city on an nos tune so I figured I fouled out my plugs. Pulled them driver side were fine but passenger side were black as hell(running rich) replaced them. Car was still doing the same then SES light came on and my 02's were dead not switching at all. So I replaced the 02's and plugs again and they looked the same driver side good and pass. black by this time the car was back to a normal n/a tune. Car is still doing the same stumbling and missing badly under 3-4k RPM even with new plugs & 02's!! Help please!!!!!!!!
Old Jan 12, 2007 | 01:49 AM
Dex's Avatar
Dex
Sounds like the passenger side injectors are staying open. You could try switching the passenger injectors with the drivers side and see what happens. If the drivers side plugs go black then you need injectors, if it stays the same it sounds like something it telling the injectors to stay open PCM. A noid light would be great i'm sure you don't have one. Its a light that will flash every time the injector opens and close really cool! It could also be a wiring problem with a wire grounded thats making that bank stay open. Are there any other codes?
Old Jan 12, 2007 | 02:09 AM
PREDATOR-Z's Avatar
Live scan with proper software will diagnose what is happening.
Old Jan 12, 2007 | 06:46 AM
V6 Bird's Avatar
Sounds like you cracked porcelain when re installing the new plugs. Get a scan tool and see what cylinder is misfiring.
Old Jan 12, 2007 | 06:58 AM
Marc '99T/A's Avatar
When I first read the title, I was going to tell you to call the police.
Old Jan 12, 2007 | 01:41 PM
BADBOYZ28's Avatar
Well I'll need to try swapping the injectors to the other side to se what it does to the plugs. Its only throwing the 02 codes nothing else as of right now. It doesnt show any missfires on any of the cylinders. But honestly I dont remember if the misfire code is on or off. None of the plugs are cracked the porcelain is fine on all of them. I was also told it might be the maf.........so I unplugged it and the car still does the same thing.
Old Jan 12, 2007 | 07:43 PM
slammedchevy's Avatar
i had this happen to me on my old mustang the o2 harness was chafed and a couple of wires where grounding out causing the same problem. not saying this is your problem but i would check it out
Old Jan 12, 2007 | 10:53 PM
BADBOYZ28's Avatar
I'll check those out but they were fine when I put the new 02's!!
Old Jan 13, 2007 | 12:00 AM
Cody Brooks's Avatar
how many miles do you have on your wires and what type ?
