Results are in on ARE Mods
410.00 RWP
370 RWT
I have played with it a little and it seems to hook fairly well. Now I am waiting for the rollcage and 12 bolt then I will will be at the track.
Thanks for the help everyone.
I ran the same cam, but on a 112LSA, for the past year with excellent results as well. I was very suprised with how awesome of low end power that cam made in my car.
With the programming I had to reinstall my stock MAF ends, the car was running too lean. It was out in the 14.5 area. With stock MAF end it runs in the 13.5 area, I am sending it back to Ed with the dyno to have him set it a little richer.
What do you think it should be set at?
Congrats on the #'s that thing will fly! Just be prepared to buy a 12 bolt especially with that Cartek clutch <img src="gr_stretch.gif" border="0"> <img src="graemlins/gr_cheers.gif" border="0" alt="[cheers]" />
Richie- The 12 bolt is on GP though TBYRNE- I should get it by middle of the month. I will catch up with you sometime, I would like to see how yours looks and compare notes.
The above post was meant in jest and in no way is meant to imply that 410rwhp is or is not a good or bad result from the aforementioned modifications. It's also not meant to imply that 99ragtopSS or ARE, or any other person in direct contact or relations, both financially or otherwise, with 99ragtopSS or ARE, need to purchase or install additional modifications or tuning.
I shift @ 6800 and have my limiter set @ 7200 <img src="gr_eek2.gif" border="0"> which I have tagged a few times and the stock bottom end is still intact. Make sure you get 4:11's.
Terry you're an ******* who never has anything constructive to say. Lets see how your almighty 435RWHP car performs @ the track. I have seen cars that make 30 more RWHP and TQ than mine does... yet they run only .10 quicker and have the same MPH. HMMMMMM! interesting. Just remember those dyno tricks don't work at the track! <img src="graemlins/gr_punch.gif" border="0" alt="[fight]" />
I just put my Strange in last weekend if you need any info. ABS, no TCS, non super strength diff, 3.73's.
Got about 300 easy miles on it before I broke a 941. Its now in my friend's garage for the 2nd weekend in a row. <img src="images/icons/rolleyes.gif" border="0">
PS If you are sticking with your stock Al d/s (assuming not steel), the 447 crossover does indeed work. Ive seen the 348 mentioned as the one you have to use with that d/s and only the 447 would work with mine.
I'm really hoping for 122mph with this new camshaft, but until I get the TP4400 in that might be hard. If only there was a way to put a fiberglass hatch on the car for race day. <img src="gr_images/icons/wink.gif" border="0">
