Is this a good setup? Texas Speed H/C
Old 01-12-2007, 08:39 PM
SSmokeDaGT's Avatar
Default Is this a good setup? Texas Speed H/C
I was going to go with the Precison Race Components Stg 1.0 LS6 Heads & 224R cam.. I was wondering if that is a good setup for street/ strip or should i just spend the extra money for the 5.3L heads. Also my goal is 400 rwhp, I currently have M6, LT's , catted y-pipe, lid, cut-out. Its a 2002 so I already have the LS6 intake manifold. I put down 336 rwhp. And was hoping to stay smog legal thats why I was going with the 224R. Maybe some of you guys from Texas Speed can chime in and give me some advice. Going to have my shop order parts on Friday. Thanks in advance guys!
Old 01-12-2007, 08:50 PM
ls2 bait's Avatar
if you are doing heads and cam at the same time id pic a head u like and then design a cam around it. knowing what i know now id never buy another off the shelf cam.
Old 01-12-2007, 09:42 PM
2001whiteSS6spd's Avatar
Actually the 5.3L heads(already comes with dual springs) are $100 cheaper than the LS6 style heads(equipped with dual springs).
With your setup I would estimate 420rwhp with that cam and 5.3L heads. I went with the 228R cam on 114 which I think is the biggest cam that can get by the sniffer.
I'm currenly installing all my parts in sig and will post up numbers in the next few weeks, so keep an eye out.
Eric
Old 01-12-2007, 10:03 PM
KY Z28's Avatar
I think I would consider a smaller runner head with that small cam. The large port LS6 heads work great if you have enough cam to fill them up. You probably will not. The 224 would be a great cam with the TSP Terminators or the AFR 205's. They will be more suited for small cams as they have a higher port velocity from the smaller runners. If you go that route, you will have nasty throttle response and a nice flat torque curve.
Old 01-12-2007, 10:53 PM
SSmokeDaGT's Avatar
2001whitess6sp - Let me know how you do.. I would probably go with the 5.3L but which stage? Let me know what you put down because i was debating the 228R.. Thanks guys keep the advice coming.. Leaning towards the 5.3L heads and the 228R..
Old 01-13-2007, 01:47 PM
SSmokeDaGT's Avatar
Alright so what do you guys think if I go with the 5.3L heads and the 228R cam? Like I said im trying to stay smog legal. Im only worried about the sniffer test
Old 01-13-2007, 01:56 PM
ls2 bait's Avatar
https://ls1tech.com/forums/dynamometer-results-comparisons/623791-prc-stage-2-5-5-3l-228-camshaft-results.html
Old 01-13-2007, 06:26 PM
SSmokeDaGT's Avatar
damn those are some nice numbers on that link.. Would I need new pushrods for that setup and if i do what size?
Old 01-13-2007, 08:52 PM
TS99V6's Avatar
I'm probably going to go with TSP Terminators to compliment my 224R. I put down 393rwhp with the cam so I should be well over 400rwhp with those heads...hopefully.
Old 01-14-2007, 02:47 AM
PREDATOR-Z's Avatar
Good choice on heads, I would get them "race finished"
Old 01-14-2007, 11:48 AM
RedHardSupra's Avatar
in CA, no LT's are legal. JBA shorties are i think the only option you got for legal setup. this means your lower/mid range is not going to be as good as LT's, but top end is almost as good. the easiest way to get 400rw+ with a smog legal system is either STS or a hidden bottle
if you must stick to H/C, then i'd recommend a smaller cam (no overlap, so might look into turbo cams) good heads and intake. not the cheap way to do it, but the smog really limits your choices. and of course, you gotta have a really good tune for it, not just some 3 wot passes on a dynocrap.
The best street cam that will (barely) pass smog is a Futral F10. if you get it on 114, it should increase your chances of passing significantly.
Old 01-14-2007, 12:11 PM
SSmokeDaGT's Avatar
Well I can take care of the LT's here. Im not worried about that. So the 5.3L Stage 2.5 heads and the 228R on a 114 to pass smog?
Old 01-14-2007, 12:17 PM
head/cam should be spec'ed out together, it's not a 'pick two offshelf components' affair, well, at least not if you want to see decent results from it. hit up PatrickG, he's really good at spec'ing out such things, just tell him you want it to be smoggable.
Old 01-14-2007, 02:29 PM
SSmokeDaGT's Avatar
Cool thanks RedHardSupra..
Old 01-14-2007, 11:39 PM
SSmokeDaGT's Avatar
So with the knowlegable help from PatrickG, I decided to get the Stage 2.5 5.3L heads and the 224/224 114LSA .. Thanks again guys and thanks again to PatrickG.. He helped me out so much.
Old 01-15-2007, 09:18 AM
john563's Avatar
I have those heads gettinstalled right now along with aportedfast 90/90set.The car already has aTR224/112 cam in it,so we hav epretty much the same set up,but Im an A4.I post results sometime late this week
Old 01-15-2007, 01:03 PM
SSmokeDaGT's Avatar
let me know how it goes
