Help: Need exact measurements of 99-02 PCV
LS1Tech Co-Founder
I need measurements of the pcv valve that goes into the driver's side valve cover. I am going to make a custom one (my friend) from Billet that I can use for a crankcase evac setup. I just need to know how wide it is, and how deep it is.
LS1Tech Co-Founder
Re: Help: Need exact measurements of 99-02 PCV
The piece that plugs into the driver's side valve cover... my buddy will make me a custom one for a crankcase evac setup...
Moderator
PSJ, the diameter of the fitting is 11/16" and the depth of the fitting to the bottom of the lip that rests on top of the rubber grommet is 5/8" with the last 1/16" (very bottom) tapered to fit into the grommet easily. Does this make sense?
