Update On Nine Ball's Engine...! Where is it???
Old Mar 11, 2002 | 07:02 PM
NastySSoo's Avatar
Default Re: Update On Nine Ball's Engine...! Where is it???
Tony, That motor sounds sick. I love it. Keep us posted!
Paul
Old Mar 11, 2002 | 07:15 PM
Ragtop 99's Avatar
[quote]Originally posted by Nine Ball:
<strong>Ragtop, I already had the "T2" cam in my 382ci motor. (232/232 .574/.574 112)
Tony</strong><hr></blockquote>
DOH! <img src="graemlins/gr_chug.gif" border="0" alt="[chug]" />
Old Mar 11, 2002 | 08:36 PM
Villain281H's Avatar
7 Second Club
From: Gainesville, Florida # of drag strips runs: ?!?!?
Hey Tony, I heard Vegas has odds going on how long your 6-speed will last, any gamblers in the crowd? <img src="graemlins/gr_jest.gif" border="0" alt="[jester]" /> <img src="graemlins/gr_judge.gif" border="0" alt="[judgement]" />
Derek
Old Mar 11, 2002 | 09:09 PM
JimmyKash's Avatar
Tony
i wouldn't be using the "street/strip" version of the jesels
spend the $$ and get the good kind
they really aren't that good of a rocker
i know a few shops who have tried to use them and haven't had good results. They could never get the tip of the rocker to correctly move back and forth over the valve stem
They called Jesel and they bascially told him what do you expect for $600?
spend the extra $400-500 and get the better ones or spend the $800 and get T&Ds. They are just as good
Old Mar 12, 2002 | 12:25 AM
Visceral's Avatar
Im inclined to agree with Kash on this one too. When I was talking with Jesel awhile back, they said the street/strip was not going to be adjustable. If you go solid, you are going to have to buy a whole new set of rockers. Go for the good ones and only do it once... IMHO.
\chris
Old Mar 12, 2002 | 01:21 AM
ls1fun's Avatar
I believe T3 is the feminator! Hence the reason to skip that one!!! <img src="images/icons/rolleyes.gif" border="0"> <img src="gr_images/icons/wink.gif" border="0">
It is a female terminator in the up and coming T3 : Rise of the Machines movie. Now back to our regularly scheduled topic!
I also was wondering about the T-56 holding up. After all , Tony has already done a bit of damage to his current T-56 with less power! <img src="gr_eek2.gif" border="0">
Old Mar 12, 2002 | 01:44 AM
Jason99T/A's Avatar
I can shift faster than you.
Tony, you better be doing 4.56s and 28" Hoosiers. <img src="gr_tounge.gif" border="0"> Mine will be here next week hopefully. <img src="gr_images/icons/wink.gif" border="0">
Also, what is the reasoning for the Jesel street/strip rockers? Is it because they fit under the stock valvecovers? As stated above, I would highly look into the T&Ds or the adjustable Jesels. You will need a C5R valvecover or a SAM spacer/long plug wires. However, this is the route I would take as it is only a little more cash.
Jason
[ March 12, 2002: Message edited by: Jason99T/A ]</p>
Old Mar 12, 2002 | 04:40 AM
xxxhp's Avatar
<strong>
Scheduled to begin machining/porting week of March 16th.
So they gonna build yours before they do mine ??!!! That's not fair <img src="gr_sad.gif" border="0"> I was first <img src="gr_tounge.gif" border="0"> . Oh well, at least I can hope that they are going to make a mistake by sending me your motor <img src="gr_grin.gif" border="0">
[ March 12, 2002: Message edited by: xxxhp ]</p>
Old Mar 12, 2002 | 10:55 AM
Nine Ball's Avatar
LS1Tech Co-Founder
I've only blew up one T56 internally, but that was when my stock rearend busted and locked up shifting into 4th gear at the track. All we had to replace were some rings and little metal square alignment blocks. Other than that, my T56 trannys have only been synchro rebuilds. One tranny typically lasts me an entire racing season.
Weatherguy, you knew I couldn't just do something that had already been done by MTI. I'm notorious for trying out new stuff, and so far everything has worked just great <img src="gr_grin.gif" border="0">
About the street/strip Jesels, MTI has been installing these on almost every 422ci since they came out. No problems yet. Could it possibly be that MTI uses proprietary custom made valves specifically designed for their motors? And yes, they fit underneath the stock valvecovers if you remove those splash guards and grind down a few bumps. They actually seem pretty nice to me, for only being $695 retail.
When it comes time to be a solid roller, I'll sell these and upgrade just like anything else. Or, I might just sell the entire motor just like last time <img src="gr_grin.gif" border="0">
If the T56 ever blows up internally, I expect a TH350 with a trans-brake, reverse manual shift will be installed. The thought of letting a computer handle my shift points makes me <img src="graemlins/gr_barf.gif" border="0" alt="[barf]" />
Tony
Old Mar 12, 2002 | 11:04 AM
onfire's Avatar
Coal Mining Director
Tony, how much rwhp did the t2 gain over the t1 in the 382? TIA.
Old Mar 12, 2002 | 11:13 AM
Colonel's Avatar
I have the non-adjustable Jesels. They look sweet to me and work just fine. We had to grind the underside of them at the transition just a little bit to make them clear the spring retainers. No big deal. A little grinding on the stock valvecover splashguards and no problem there either.
So how are they different than the adjustable Jesels other than not being adjustable?
Old Mar 12, 2002 | 11:26 AM
  #32
Nine Ball's Avatar
LS1Tech Co-Founder
Tom, I don't have any accurate dyno numbers from before/after the T1 to the T2 cam. Too many "dyno" variables changed:
T1 cam, Draglite wheels, stock rear with 3.73s = 455 rwhp and 442 ft-lbs
T2 cam, stock rims/tires, Moser 12-bolt with 4.10s = 455 rwhp and 435 ft-lbs
Tony
Old Mar 12, 2002 | 02:13 PM
  #33
Nine Ball's Avatar
LS1Tech Co-Founder
Here is a picture of the Jesel Street/Strip rocker setup. These are still better than stock rocker arms, we haven't seen any failures with them yet. There is still a mounting bar that goes all the way across, and the pairs are bolted to it.
Tony
Old Mar 12, 2002 | 02:20 PM
  #34
Terry Burger's Avatar
Why bother with rocker arms for a hyd cam anyway. Just go solid cam from the start if thats what you want to do.
Old Mar 12, 2002 | 02:24 PM
  #35
Nine Ball's Avatar
LS1Tech Co-Founder
Just a durability concern Terry, nothing more. This cam is just like Colonel's, it has 0.610" lift and our springs can only handle 0.620" lift, so it should be working the valvetrain pretty hard. I've spilled the bearings on stock rocker arms once before, and am installing these at the recommendation of MTI.
Solid roller would be sweet! But, I can't spend the extra money.....this month <img src="gr_grin.gif" border="0">
Besides, aren't people curious about how a fully loaded HOG 6-speed will run with Colonel's engine in it? <img src="gr_grin.gif" border="0">
Tony
Old Mar 12, 2002 | 07:41 PM
  #36
onfire's Avatar
I can't wait to see the results of that motor combined with a guy (Tony) that can shift a 6 speed.
Old Mar 13, 2002 | 12:52 AM
  #37
JimmyKash's Avatar
[quote]Originally posted by Colonel:
<strong>
So how are they different than the adjustable Jesels other than not being adjustable?</strong><hr></blockquote>
normal shaft rocker systems have a complete bar that goes across the entire head that is solidly mounted where the guide plates would be
the rockers are then bolted into these bars...
Where as the street/strip version just replace the use of using guideplates and you use a pair of rockers
here is a pic of a shaft system on cendres old z:
Old Mar 13, 2002 | 11:18 AM
  #38
pewter99SS's Avatar
wow, that's gonna be fun to watch
Old Mar 14, 2002 | 01:46 AM
  #39
ls1fun's Avatar
I thought you had said you tweaked the input shaft on your T56???
Old Mar 14, 2002 | 08:09 PM
  #40
FST01m6's Avatar
Tony.. congrats on the set-up. Did you ever know that your my hero ?? <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
I got 2 questions for ya if you dont mind please:
1. What do you expect to shift at ??
2. Are you going to need a new clutch for this set-up, and if so, which one ??
