Stock GM MLS Head Gaskets??
I'm trying to find out what's the thickness of a compressed stock GM MLS head gasket, on the 5.7L and the 6.0L gaskets.
I did a search and found a few numbers but nobody was really sure. Some said .060, .054, or .051 on the 5.7s, and .054, .052, or .051 on the 6.0s.
Does anybody know for sure what the compressed thickness on these gaskets are?
![Icon Confused](https://ls1tech.com/forums/images/smilies2/icon_confused.gif)
8 sec potential, 12 sec slip
Originally Posted by NeverT00fast
Is it safe to use the 6.0 gaskets on a 5.7 block?
Originally Posted by PREDATOR-Z
6.0 gaskets are 4.060 bore
6.0 gaskets AFAIK are 4.030, not 4.060. Regardless, using them on a 3.898 bore (5.7) will open up more area for detonation. Not worth it, in my opinion. Just use the stock GM MLS gaskets for the 5.7 engine if you are using the stock LS1 bore heads. However, if you are using heads like 317's with the 4.000 bore, then you would want to go with the 6.0 head gaskets. You want to use gaskets for the largest bore of your head/engine pair.
Originally Posted by Prey4Me
Is 3.898 the stock bore size for the 5.7? I need head gaskets and have AFR 205cc heads, what would be the correct gasket to use? This motor will have nitrous soon if that makes a difference. I'm looking at cometics, and not sure which bore is called for in this case.
Originally Posted by hammertime
If the deck surface outside the combustion chamber is all flat, wouldn't you want the head gasket to match the bore diameter? Is the chamber actually .100 wider on a 317 head than a 243?
There might be 2 types of 6.0 MLS but I don't remember. I know mine are 4.060
You do not use a gasket that overlaps your bore, it is always a bit bigger.
Using a bigger bore gasket has no detonation issues, but you loose compression and you do not want the gasket bores to be beyond the cylinder sleeves, because upon charge explosion, you do not want the sleeve/block area to be exposed.
Using bigger bore gasket actualy increases your quench areas, which at proper thickness is not bad.
No, I run these on my 4.030 bore 370 and I measured them. They are 4.060 bore.
I would go with Cometics if you're gonna spray. Cometics offer a wide range of bore and thickness sizes for you to go with. The stock bore for the 5.7 is 3.898 and the GM MLS 5.7 gasket bore size is 3.905, if i recall correctly. With the AFR 205's and the stock bore (5.7) I would go with a Cometic 3.905" bore and .040" thickness. This would give a better quench than the stock MLS gaskets so it would suit you much better, especially when using the juice.
![Sad](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_sad.gif)
![Thumb](https://ls1tech.com/forums/images/smilies2/thumb.gif)
It really doesn't matter because GM doesn't make 5.7L gaskets anymore. All the part numbers were superseded by the 6.0L gaskets. I went through this a year ago when I was doing my head swap. I had to use the 6.0L gaskets on my stock bore engine and haven't had any issues at all.
Thanks for giving answers that I can understand. Some of this stuff can get confusing real quick! The only thing now is waiting 3 weeks for them to get here
. Thanks again for making things easier to understand
BADFNZ - According to your sig you're about to get a "vacation *******". I'd assume this one differs from your hard working ******* that never takes one
![Tongue](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_tongue.gif)
